Thread: Hard start with heat on
Results 1 to 10 of 10
  1. #1 Hard start with heat on
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Now that's it's cooling down and I'm leaving the heat on I've noticed my car is starting up kind of hard compared to usual. When the heat is in the off position it starts up normal. These are cold starts too if that makes a difference. It did this when the ac is on to but that makes sense to me. Is there something that could be causing this? I don't remember it being like this the past few years. It's also not super cold out usually around 50 when this is happening. And if I drive for a while then turn it on again after going into a store or something it starts up no problem with the heat on already.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Hard start with heat on
    vac leak in the hvac controls maybe.
  3. #3 Re: Hard start with heat on
    Buffalo, NY
    where/how would i figure out if that's it?
  4. #4 Re: Hard start with heat on
    maybe you can hear a hiss from the dash or some thing. smoke test might work too.
  5. #5 Re: Hard start with heat on
    Feb 2013
    37.295091, -121.930053
    I gotta ask how is the battery?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: Hard start with heat on
    Buffalo, NY
    battery was new in either march 2012 or 13 I'd have to look at it to be sure.
  7. #7 Re: Hard start with heat on
    Buffalo, NY
    Also what's the best way to smoke test? Does autozone rent those out?
  8. #8 Re: Hard start with heat on
    check the vac line that runs under the fuse box, it could be broken.
    search youtube, people make em out of fog machines.
  9. #9 Re: Hard start with heat on
    The pcm won't command the AC on until after the car is started and up and running. So that shouldn't cause an issue. Heat vs AC being on shouldn't cause an issue. The climate control if it had a leak would be defaulting to a mix of defroster and floor vents.
    When was the last TB cleaning?
  10. #10 Re: Hard start with heat on
    Buffalo, NY
    I've never cleaned the TB so I'm assuming it's never been done. Now that you've pointed it out Bill I do have the car on defroster or defroster/floor since it's cool out right now. But when he starts hard with the AC on it's always on the max AC option. Would a dirty TB still cause it to start hard only when the heat or ac is on and not when everything is off? I figured that having them on made it draw extra power somehow but you're saying they don't kick on until the car is running.
  1. Hard to start
    By Swole in forum General Tech Discussion
    Last Post: 03-15-2014, 07:18 AM
  2. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  3. Hard to start
    By vertebrate in forum General Tech Discussion
    Last Post: 08-26-2011, 01:51 PM
  4. hard start
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 12:43 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
