Thread: Heavy Isolated Misfire Under Load
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 41 to 60 of 197
  1. #41 Re: Heavy Isolated Misfire Under Load
    What if his roller lifter collapsed? I would check that out before pulling the head.
    I have 4 LS7 lifters if you want them Joe if that is what it ends up being.
  2. #42 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Quote Originally Posted by Drunkie View Post
    Wouldn't I hear some kind of ticking if the lifter collapsed?
  3. #43 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Got the head off woooo.
    No damage to the piston wooo. They sure look ugly though.
    I haven't got a chance to remove the valve because I forgot my spring compressor at home.
    i also manage to break all the rear injector o-ring retainer things.
    I'll post pictures when I get home.
  4. #44 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    soooooo you gonna miss the meet????
  5. #45 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Sorry, my camera is a potato
  6. #46 Re: Heavy Isolated Misfire Under Load
    i wish inside my engine looked that clean. mine looked like the inside of a old BBQ lol
  7. #47 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Check your lifters, might as well if you are this far.
    Will do!
    VV
  8. #48 Re: Heavy Isolated Misfire Under Load
  9. #49 Re: Heavy Isolated Misfire Under Load
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    WOo! Glad to see my head will be useful xD
    04 GTP -HAI, 1.9 rockers.
  10. #50 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Who knows if it will..
    Nothing has been confirmed yet.
  11. #51 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Here's the suspected bad valve. It has a burn mark on it.
    Also I cleaned the new head surface with a wire wheel. Did i **** up?
  12. #52 Re: Heavy Isolated Misfire Under Load
    Aug 2013
    Sandy, UT
    Quote Originally Posted by Jomamma View Post
    A wire wheel... No... Why... should've just cleaned the gasket material off with a razor blade...
  13. #53 Re: Heavy Isolated Misfire Under Load
    Aug 2013
    Sandy, UT
    You might be OK, but I don't know. I've never taken a wire wheel to a gasket mating surface.
  14. #54 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I saw a guy on youtube do it for a head gasket change on a 3800
  15. #55 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Since I cannot see any visual damage on the lifters and valve should I check any thing else
  16. #56 Re: Heavy Isolated Misfire Under Load
    put that valve in a drill, and spin it. you'll know asap if its got a bend or not.
    the lifter could be jacked up too. maybe worth changing it while its open.
  17. #57 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Car is running like complete ****. I have several codes. I think I ****ed up the wiring harness because the trans is whining.
    Oh and that miss is still there when I give it quick throttle.
  18. #58 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    p0118- High coolant temp ; i broke the temp sensor
    p0560- System voltage > 16; It was like 18-20v wtf
    p1115- coolant temp sensor.
    p1635 "5V Reference (B or 2) Circuit" ?
    I also noticed the PCM isnt telling me its misfiring, but im pretty sure it is.
  19. #59 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    It idles very high until it warms up .
    Then it takes a lot of gas to get it to move from a stop.
  20. #60 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Okay I fixed all the codes. Its because the coolant temp sensor was smashed leaving only the three prongs left.
    I connected its wire on the harness to the three spring wrong.
    Anyway it still misses. All that work for nothing.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
