Thread: Heavy Isolated Misfire Under Load
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 197
  1. #21 Re: Heavy Isolated Misfire Under Load
    still missing on cylinder one?
    Check the pushrods, if that is good, you may have a collapsed roller.
  2. #22 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Yes still cyl 1
    Ill check the push-rod again it looked straight last time I looked at it.
    Collapsed roller? On the rocker arm? Im thinking maybe a bent valve.
  3. #23 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Pretty bummed out about this.
    The more I think about it. Something had to bend because of the lower pivot point of the rocker.
    When I pulled the rod out a few days ago. It looked straight. But maybe I didn't look at it well enough.
    I really don't want to pull the head to inspect the valve. Ill open it up again tomorrow. If the rod is straight, I guess I'll be pulling the head.
  4. #24 Re: Heavy Isolated Misfire Under Load
    take the rod out roll it on something that is dead flat. kitchen counter, table. it has to be smooth and flat.
  5. #25 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    That's what I was planning on doing. First thing in the morning.
  6. #26 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Here's a picture comparing Cyl1 exhaust rocker (left) Cyl3 exhaust rocker (right).
    There was some damage to it from sitting on the shim but it should be fine.
    Cyl1 exhaust pushrod on top ( markings are from the push rod rubbing on the head gasket ) vs Cyl3 exhaust pushrod on bottom
    Straight as an arrow.
    I tried to get a picture of the valve stem / guide. Let me know if you guys see anything.
    At this point what else can it be besides a bent valve?
    I even switched both pushrods and rocker arms. The miss did not move.
  7. #27 Re: Heavy Isolated Misfire Under Load
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I can't even see them.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  8. #28 Re: Heavy Isolated Misfire Under Load
    sounds like a bent valve then.
    do a compression test on that piston. see if it makes peressure.
  9. #29 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    yeah this isnt the first time someone has tightened down high ratio rockers without letting the lifter bleed down...most of the time it just kill sthe valve seal and you get oil burning.
    on those instances where the piston is at tdc....you can open the valve right into the piston...as if you had .7 valve lift.
    even oem rockers could do this.
    do a leakdown test, compression test might not be very helpfull.
    just use the spark plug portion of the hose and blow into it with it at tdc compression
    ~James~ Psychotic Gearhead
  10. #30 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    rotate the crank 30* of either side of a cylinder TDC and all your pistons will be ~3/4"+ down in the hole to keep you safe....or just tighten a half/full turn and move to the next to allow the lifter to bleed out the oil from the plunger
  11. #31 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Quote Originally Posted by Turbocharged400sbc View Post
    I appreciate the detailed post. Thank you.
    However, you're scaring me. Youre saying that the piston could have kissed the piston?
    When it misfires it sounds almost as if the valve isn't opening enough to exhaust the gasses.
    At this point I feel as if the head needs to come off. I've checked everything else and I feel anymore diagnoses may be a waste of time, which I have none of.
  12. #32 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    DONT PULL THE HEAD WITHOUT A LEAKDOWN
    you need to find out which valve hit, yes the valve head may have hit your piston...however it likely didnt do anything other than leave a cosmetic mark on the piston, but tweaked the valve...
    air hissing out the exhaust or intake/both will tell you wheterh bboth are bent or just one.
  13. #33 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    how the hell was the #1 rocker sitting low enough to hit the HS stands/shims?
    that right there probably led to the exh valve being opened far enough to bend as the fulcrum was moved closer to the piston, changing the geometry for the worse.
  14. #34 Re: Heavy Isolated Misfire Under Load
    some how he was missing the pedestal, either forgot to install in under the rocker, or it broke and fell in the engine. either ways he was one short till he got the new one.
  15. #35 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    likely the exh valve is bent
  16. #36 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Pretty positive it was the valve with the missing rocker pedestal.
  17. #37 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    So my piston should be alright?
  18. #38 Re: Heavy Isolated Misfire Under Load
    hangover park IL
    yeah...dunno...without the pedestall...its likely your valve could have been in the postion of having up to 1" valve lift....at that point its possible there may be more damage than just kissing it....
  19. #39 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Does this mean you won't make it to the meet jomamma
    Sent from Hell
  20. #40 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    At this point who knows.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
