Thread: Heavy Isolated Misfire Under Load
Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 197
  1. #81 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    I think you need to pay Scotty to come fix it.
    I concur
  2. #82 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I've come this far, I'm not gonna give up.
    Swapped the injectors around for ****s and giggles. No change still missing on cylinder 1.
  3. #83 Re: Heavy Isolated Misfire Under Load
    Antioch, IL
    maybe ill get the puller back in spring
    2009 Challenger SRT8
    Expert at being gay.
  4. #84 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    It has to be a lifter. Its the only other possible thing I can think of.
  5. #85 Re: Heavy Isolated Misfire Under Load
    Or that fubared cam of yours. ....
  6. #86 Re: Heavy Isolated Misfire Under Load
    ^^^wiped cam lobe?....
  7. #87 Re: Heavy Isolated Misfire Under Load
    yeah thats always possible too. damn you pedestal!!!!!
  8. #88 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I know its possible. I looked at it through the lifter hole and it looked fine. And the roller on the bottom of the lifter looked identical to the others. No damage or scaring.
  9. #89 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    No metal in the oil either.
  10. #90 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Pulled the valve cover again today. Pulled the fuel pump fuse and had a friend turn the engine over while I watched the rockers movement.
    When comparing the "troubled" rocker with another, they seemed to be rocking the same distance down. ... I know I should use a dial to measure for sure.
    Anyways, this leads to believe the cam is fine and the lifter isn't pumping up.
  11. #91 Re: Heavy Isolated Misfire Under Load
    If the lifter wasn't pumping up.. wouldn't that cause movement to be impaired?
  12. #92 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    When the engine is on and pumping the rest of the lifters with oil, yes the one not being pumped up would be impaired.
    However, with the engine off, they shouldn't be pumped up. Therefore making the rockers look like they're all moving the same.
  13. #93 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Put a new lifter in today. Took it for a quick ride. Went wot a few times. And it felt good.
    Came back home put the new pulley on and the second time I went wot with the new pulley it started to misfire again.
    I wanna say its the cam but I checked the height the lifters were rising as I turned over the motor and everything checked out. I marked the highest point on the lifter on a different cylinder then swapped the lifter over to the suspected bad lifter. When I turned it over it came up to the same spot.
    Damn this car man.
  14. #94 Re: Heavy Isolated Misfire Under Load
    that lifter looks chewed up or is it just the pic?
  15. #95 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I dont think so, its oil sitting in the top. Thats the lifter from the good cylinder moved to the bad cylinder.
  16. #96 Re: Heavy Isolated Misfire Under Load
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    So bigger pulley......no misfire......smaller pulley...misfire. Seems you have your answer right there......you don't have misfire......you have detonation issues. Betting your pistons and combustion chambers are all carboned up causing this. In simple terms, your combustion areas and pistons are so carboned up that the compression ratio is through the roof. Bring the car to normal operating temp. Get a squirt bottle full of ice cold water. Spray said ice cold water into intake and let it blow the carbon out as you rev it by hand.
    The other option is to run your tank dry and put true racing fuel in it. Bet your issue goes away then.....as per previous paragraph.
    Official GPF Red Neck
  17. #97 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Im open to new ideas, however I don't think that is the case here. I'll admit when I pulled my head 2 weeks ago all my pistons were pretty dirty(see page 3). If that was causing it then all the cylinders would be missing or "detonating". Besides, I'm not really seeing any KR.
  18. #98 Re: Heavy Isolated Misfire Under Load
    Feb 2013
    Ohio
    Spend a little money and put racing fuel in it. See if it goes away.
    Also, your #1 hole looks worse than the other two. I know it may not seem like much, but, remember, it only takes a .030" bore over to turn a 350 into a 355. Since the machining of that era still was not the best, any extra buildup in the chamber could have an adverse affect on it.
  19. #99 Re: Heavy Isolated Misfire Under Load
    Everything mechanical seems fine then. Going back to what bill said earlier...You have a huge vacuum leak somewhere...or something electrical.
  20. #100 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    No that lifter looks a tad bit beat
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
