Thread: Heavy Isolated Misfire Under Load
Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 197
  1. #61 Re: Heavy Isolated Misfire Under Load
  2. #62 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    The only thing left is the lifter or the injector.
    The lifter looked fine compared to others. But who knows if its actually pumping up or not.
    I probably should have swapped the lifter to another cylinder to see if the miss moved.
    And I don't think it can be the injector because the problem started immediately after the rocker install.
    Any ideas?
  3. #63 Re: Heavy Isolated Misfire Under Load
    i thought you were gonna pick up a lifter. i would have swapped it.
    maybe its best at this point to fire it up vc off, see what that rocker is doing. maybe you can see or feel the push rod not being tight due to a bad lifter.
  4. #64 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    I don't think the parts store has them. Or else I would have picked one up.
    Is is to safe to fire it up with out the valve cover?
  5. #65 Re: Heavy Isolated Misfire Under Load
    Yup just expect a little oil might spill out onto the manifolds/ or headers
    04 Comp G.
  6. #66 Re: Heavy Isolated Misfire Under Load
    they used to sell clips that kept oil from shooting all over. you could lay a rag over them.
    when i rebuilt my firebirds 400 i fired it up v/c off and it shot oil 20 feet up and hit the side of the house. it was crazy, 8 fountains of oil pumping at the house. that was fun to clean up i tell you.
  7. #67 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Yay that sounds really safe
  8. #68 Re: Heavy Isolated Misfire Under Load
    Damn Joe. Yeah I would fire it up without the valve cover, see what happens.
    Joe I still have those 4 LS7 lifters, when you go to install the lifters, soak them in a bowl of oil first.
    Also...really crazy thought and for ****s and gigles; put the stock rockers on the front bank.
  9. #69 Re: Heavy Isolated Misfire Under Load
    Lets recap what you have done and just check off what you have done:
    -New spark plug
    -new spark plug wire
    -new coil pack
    -swapped injectors
    -check signal to said injector
    -check ICM
    -check valves
    -check rockers
    -check pushrods
    -check lifters
  10. #70 Re: Heavy Isolated Misfire Under Load
    Never Never Land
    Is it remotely possible the cam was damaged from the missing spacer?
  11. #71 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Quote Originally Posted by Drunkie View Post
    -New spark plug Check (swapped with another cylinder; no change, still cyl 1 miss)
    -new spark plug wire Check
    -new coil pack Check ( swapped coil packs around; no change, still cyl 1 miss)
    -swapped injectors Haven't done this yet
    -check signal to said injector Haven't done this yet
    -check ICM Check
    -check valves Check
    -check rockers Check
    -check pushrods Check
    -check lifters Check ( visually checked, but who knows if its actually pumping up)
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I've thought about this, I peered down at the cam when i pulled the lifter and it looked fine.
    Im thinking its not spark or fuel related because the problem occurred immediately after the rocker install. The car hasnt ran right since I put them in.
    I leaning towards the lifter now.
  12. #72 Re: Heavy Isolated Misfire Under Load
    Do the injector swap around, takes 15 minutes.
  13. #73 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Ill swap the injector. Then ill pull the vc and see what going on, not that ill think ill be able to really see anything. After that I suppose ill swap the lifter out for a new one.
  14. #74 Re: Heavy Isolated Misfire Under Load
    Enfield, CT
    Quote Originally Posted by Jomamma View Post
    I think you should just pull the VC now...
  15. #75 Re: Heavy Isolated Misfire Under Load
    You said the car is idling high? That still happening? if so.. you likely have a huge vaccum leak.
  16. #76 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    No all the weird things going on stopped when I fixed the coolant temp sensor.
  17. #77 Re: Heavy Isolated Misfire Under Load
    How about taking a 194 bulb and putting it into the injector plug just to make sure the injector is getting power/ground. You should see a flashing light when it's running.
  18. #78 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    It only happens when I give it gas/go into boost.
    You think that my injector would stop getting power when I get on it?
  19. #79 Re: Heavy Isolated Misfire Under Load
    No, I thought it was also idling badly
  20. #80 Re: Heavy Isolated Misfire Under Load
    I think you need to pay Scotty to come fix it.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
