Thread: Heavy Isolated Misfire Under Load
Results 1 to 20 of 197
  1. #1 Re: Heavy Isolated Misfire Under Load
    Never Never Land
    Is it remotely possible the cam was damaged from the missing spacer?
  2. #2 Re: Heavy Isolated Misfire Under Load
    Howell, NJ
    Quote Originally Posted by Drunkie View Post
    Lets recap what you have done and just check off what you have done:
    -New spark plug Check (swapped with another cylinder; no change, still cyl 1 miss)
    -new spark plug wire Check
    -new coil pack Check ( swapped coil packs around; no change, still cyl 1 miss)
    -swapped injectors Haven't done this yet
    -check signal to said injector Haven't done this yet
    -check ICM Check
    -check valves Check
    -check rockers Check
    -check pushrods Check
    -check lifters Check ( visually checked, but who knows if its actually pumping up)
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I've thought about this, I peered down at the cam when i pulled the lifter and it looked fine.
    Im thinking its not spark or fuel related because the problem occurred immediately after the rocker install. The car hasnt ran right since I put them in.
    I leaning towards the lifter now.
  1. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. 99 gtp misfire #1 under load /in boost Heelp!!
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2012, 12:50 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
