What if his roller lifter collapsed? I would check that out before pulling the head.
I have 4 LS7 lifters if you want them Joe if that is what it ends up being.
Got the head off woooo.
No damage to the piston wooo. They sure look ugly though.
I haven't got a chance to remove the valve because I forgot my spring compressor at home.
i also manage to break all the rear injector o-ring retainer things.
I'll post pictures when I get home.
Check your lifters, might as well if you are this far.
Car is running like complete ****. I have several codes. I think I ****ed up the wiring harness because the trans is whining.
Oh and that miss is still there when I give it quick throttle.
p0118- High coolant temp ; i broke the temp sensor
p0560- System voltage > 16; It was like 18-20v wtf
p1115- coolant temp sensor.
p1635 "5V Reference (B or 2) Circuit" ?
I also noticed the PCM isnt telling me its misfiring, but im pretty sure it is.
Okay I fixed all the codes. Its because the coolant temp sensor was smashed leaving only the three prongs left.
I connected its wire on the harness to the three spring wrong.
Anyway it still misses. All that work for nothing.
