Thread: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind engine
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 160
  1. #121 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    SE Level Member zbban1's Avatar
    May 2014
    Mi
    Okay, thanks.
  2. #122 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    i pull behind my local stores and raid the card board containers out back. take a large box cut it in 1/2 good for working on and under the car and catching drips. its free no cares about getting more.
    you can slide out from under a car on a sheet of card board so easy compared to with out any.
  3. #123 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Or if you walk into any store ever and ask for boxes they will give them out like candy. At Menards a guy was moving so we saved a mornings worth of boxes for him and left them in the bed of his truck and by the time I left you couldn't see the truck anymore.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #124 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Yep, that's what I did, ran down to the local grocery store and asked them for a couple of boxes. Pizza boxes work well, too, but we didn't have any of those. That's a weekend item, I guess...lol. And yes, you do slide better on cardboard! I'm going out to put the cardboard down and take a few pics of my cleanup job before it starts pouring......
  5. #125 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    The top pic is of a new mount from AZ, mine is the bottom one. I see now just how smushed mine really is! lol About 2 mins. after I got outside it started pouring down rain, so I am waiting on putting down the cardboard till it stops.
    I did clean it really good, so why is it looking so oily? Is it because there's still fluid coming out of it when it moves?
  6. #126 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    id find and fix your leak before doing the mount. as the oil leak will just kill the new mount.
  7. #127 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Mar 2012
    NC
    Factory mount is hydraulic (aka filled with fluid.) Things that leak in that area...oil pressure sender, front crank seal, oil filter gasket, or oil filter housing gasket. And last but not least, that stupid stock mount.
  8. #128 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    That's exactly what I plan on doing, that is, if mother nature decides to cooperate.
  9. #129 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    I've already eliminated the oil pressure sensor/switch/sender, the oil filter gasket, the oil filter housing gasket and valve cover gaskets. Oh, and didn't see anything wet coming from the balancer area either. I know the oil pan does leak right where the "pointy end" is, that is, nearest to the mount/bracket. After this rain I'm going to re-check everything once again, just to be positive.
  10. #130 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Just finished talking with my eldest son and he's buying a house with a pole barn, so in about a month he'll be moving there. Another $64,000 question...lol...will it be ok to drive it as is for another month? I'm thinking it would be, but would like to know what others have to say about it, if you would, please. I only drive it 2-3 days a week and not long distances. He'll have a cherry picker then, too, and all 3 of the boys will be helping me.
    Actually what'll end up happening is them telling me to get out of the way and just "supervise". LOL Fine by me......
  11. #131 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Apr 2012
    Dayton, OH
    Just check the oil level regularly and if it smells like burning oil I wouldn't drive it. Depending on where its leaking I'm not sure if it would effect oil pressure. But scotty and other should know, my 3800 doesn't leak any oil
    Just coolant....
    2012 F150 STX
  12. #132 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Will do. Don't know if I'd rather have a coolant leak or an oil leak...lol.
  13. #133 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Apr 2012
    Dayton, OH
    Coolant all day, because the oil pan is a bish to replace or any of the other spots they leak from.
    2012 F150 STX
  14. #134 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2012
    Where 4T65E's were born
    Neither are good lol. Both can be hard and easy to fix depending on what it is. I'd say drive it once, and check the area and see if it's horrible already. If not you could wait and keep checking
    Just fix the leak Russ lol
    Sold.
  15. #135 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    what you need a cherry picker for?
    motor mounts can be done with a floor jack and a 2x6 across the trans and oil pans, unbolt the mounts jack the engine up so replace.
    you'll want to change the trans mount 99% of the time when you do a motor mount.
    oh take the two strut mounts off before jacking the engine up, aka dog bones.
  16. #136 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    As it looks as if the rain is done for awhile, I think I'll take it out for a spin and bring it back and let it sit on cardboard over night.
    I saw a couple of videos for replacing the motor mounts and the oil pan and both looked easier for us to do with the cherry picker. I'm not really sure how to do it with the 2x6 and a floor jack, haven't seen any videos or write-ups on doing it that way. I want to do both the mounts and the oil pan at the same time.
  17. #137 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    ok im on board now, lifting the engine should help a ton when doing the oil pan. that things a pita.
  18. #138 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    May 2014
    Mi
    Yes, it IS going to be a pita! Instead of trying to do it in a parking lot, I'd rather wait and be able to work on it inside a building. No worries if it rains, etc.
  19. #139 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Enfield, CT
    true...
  20. #140 Re: Pics..Help me find cause of oil leak.leaking on side of passenger tire behind eng
    Dec 2013
    WORK
    Quote Originally Posted by zbban1 View Post
    I have been outside checking out this leak. Found a flashlight, btw lol. The sensor is dry, as are the wires and connector, so that's not the cause of my leak. I know my oil pan has been leaking a bit, but didn't think it was getting THAT bad. I did manage to take a few pics after I took off that splash guard thingy that's next to the oil filter. My first reaction...YUCK! Motor mount looks soaked in oil and there was a bunch of oil sitting in that bracket that mounts on top of the motor mount. I've watched a couple of videos on replacing the oil pan, which I need to do but don't want to attempt it myself (and can't afford to pay big bucks that some places charge to do it) and I've seen what a new mount looks like and mine is actually mushy on the end that faces the rear of the car. Would that be because of the oil dripping from the oil pan?
    I don't want to hijack this guy's thread, should I start another thread and post the pics in that thread?
    Your fine. Are you sure it is not the oil sensor. Mines is the oil sensor. When i started up my car i seen oil dripping from it slowly but Im sure as i drive the car the oil pressure goes up which cause it to drip more
    Are these channel locks fine to replace the oil sensor? Dont judge them, i left them outside in the rain once lol
  1. Wire hanging from under car near Passenger Side tire
    By gamefreak in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2013, 03:35 PM
  2. Clunking from passenger side tire area
    By DJE in forum Introductions/Noob Questions
    Last Post: 04-21-2013, 07:08 PM
  3. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  4. Passenger Side Leak
    By Toney Halbert in forum General Grand Prix Discussion
    Last Post: 03-13-2012, 09:13 AM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
