Thread: Knocking problems
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 101 to 120 of 126
  1. #101 Re: Knocking problems
    Antioch, IL
    just for the record, those headers gave me ZERO problems chris... ZERO
    2009 Challenger SRT8
    Expert at being gay.
  2. #102 Re: Knocking problems
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    thanks, it makes me feel soooooo much better
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #103 Re: Knocking problems
    Jun 2012
    Illinois
    new sensor in and i had to do the wires again since the header made it melt. I think i routed it away from the header this time. Still seeing some knock. I had a couple of pulls with 0 knock and then a couple with 2 or 3*. will false kr be give you a couple degrees say at 4500 and then drop to zero for the rest of the pull?
    chris
  4. #104 Re: Knocking problems
    Jun 2012
    Illinois
    so little update... new MAF sensor and o2 sensor are in. Also checked all plugs and are gaped at .055, i also moved my header clamps so it wouldn't be hitting. On some pulls i'm getting no knock and then a couple pulls there is still some. The upper mounts are poly. Any other ideas where this knock could be coming from? i'm on a 3.5. car runs well and pulls pretty well. Does the IAT sensor position matter that much. its right outside by the plug of the maf sensor.
    Thanks,
    Chris
  5. #105 Re: Knocking problems
    try gaping the plugs at 0.50.
    no idea on the ait. i put mine back in somewhat of a stock location in my hot air cone set up.
  6. #106 Re: Knocking problems
    Jun 2012
    Illinois
    ugh but those rear plugs are such a pita
  7. #107 Re: Knocking problems
    Quote Originally Posted by chris99gtp View Post
    you got headers now right? back plugs are cake with headers. with my huge ass hands and all them brackets removed its easy to get to em. i dont even rock the engine any more.
  8. #108 Re: Knocking problems
    Jun 2012
    Illinois
    yeah thats true. so youre saying gapping to .050 should work? if not any other suggestions?
  9. #109 Re: Knocking problems
    every car is a bit different, all you can do is play with the gap, see how it feels. and scan for KR as well.
    i felt a difference going from 53 to 50, its not like its a big jump, but it made a difference.
  10. #110 Re: Knocking problems
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    o2 wire cant sit on any spark plug wires aswell, will give false readings/ mess it up, just a tip
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  11. #111 Re: Knocking problems
    Jun 2012
    Illinois
    ^^really? i had it wire tied to one wire to help route it around the header...
    In other news, i just got another code P0137. low voltage bank 1 sensor 2. yay.
  12. #112 Re: Knocking problems
    u se these plug wire clips. they are held in place so when laid flat they go to the plug they belong to, left middle right. with the clips i make the wires snug enough to keep them off the pipes on the back, then let the wires come over the top.
    this pic is pre headers, but ive ran them the same before hand, still works fine.
    i ran my o2 extension down the pass side strut tower to the sub frame, follow the sway bar to the o2 sensor, this is the only way i could see to route it with it getting melted. i made my own extension, added 3 feet of wire to the factory harness.
  13. #113 Re: Knocking problems
    Jun 2014
    Ontario Canada
    yep, cant have the wire touching the spark plug cable, ever grab onto one of those cables? trust me you wont hold on log, it hurts lol, so if you can feel it through the cable, same thing for the o2, the voltage would throw it off if its getting extra juice from one of those cables you strapped to
  14. #114 Re: Knocking problems
    Jun 2012
    Illinois
    it was a little crispy when i saw the wire. just taped it up for the mean time... So i also just found out that i'm pretty sure the Previous owner of the car had the older style MAF. so anyone have an 01 maf laying around? could this be part of my problem? i'd assume yes
  15. #115 Re: Knocking problems
    Jun 2012
    Illinois
    to the top
  16. #116 Re: Knocking problems
    Jun 2012
    Illinois
    nobody?
  17. #117 Re: Knocking problems
    Jun 2012
    Illinois
    Finally fixed it. 0 Kr on a 3.5. Time to go to a 3.4
  18. #118 Re: Knocking problems
    Oct 2014
    How did you fix it?
  19. #119 Re: Knocking problems
    Antioch, IL
    o2 sensor/real extension
  20. #120 Re: Knocking problems
    Jun 2012
    Illinois
    Haaaa so now I just got 2 more codes. P1133 P0137
  1. Knocking?
    By Timing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2013, 07:34 PM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
