Thread: Running hot and at wits end
Results 1 to 20 of 22
  1. #1 Re: Running hot and at wits end
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If your hose is collapsing you need a new radiator cap. Also you would have been better off switching over to green coolant when you flushed it.
    If it's getting hot at low speeds and stopped but not at higher speeds then check if your fans are coming on. More than likely that is your culprit.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Running hot and at wits end
    Jul 2014
    Pineville, Louisiana
    Quote Originally Posted by indygrandprix View Post
    The fans are working and I just put a new radiator cap on. THe green coolant you mention is that just normal antifreeze and if so should I dilute it at 50/50 also? I just ran the vehicle for 15 minutes and it got up to the last notch before going into the red. The upper hose has what seems to me to be too much pressure. I have started bleeding it again, still a good bit of air between spurts of coolant.
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. At wits end
    By jrsteinbronn in forum General Tech Discussion
    Last Post: 08-02-2012, 08:57 PM
  3. At wits end... Security problem?
    By Carlos773 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2012, 10:28 PM
  4. At Wits End (97 GP GT)
    By ThaYeti in forum General Tech Discussion
    Last Post: 08-26-2011, 09:17 PM
  5. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
