It honestly sounds kinda normal, mine runs at about 188-195 at speed and up to 212 just zipping around town. Got anyway to digitally read coolant temps, idk if your DIC shows it or not. The no heat still seems like the core has air in it or something or your rad is really low, I could be overlooking something simple iv been in the sun all day.
You can check for play in the water pump which could indicate its going out.
Sent from the Milky Way
No digital temp readout, radiator is definitely not low, unfortunately I can't see the weep hole on the water pump, , but still seeing no drips on concrete, so what is your thought on a bad thermostat as was mentioned by another poster?
