Thread: Pros and cons of going catless
Results 1 to 10 of 10
  1. #1 Pros and cons of going catless
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Putting on sd headers as i write this. The cat almost looks new. Is it worth reaming out and going catless with the defouler trick or should I just put the cat back In. do I make any gains by going catless?
    Thanks
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Pros and cons of going catless
    The headers have a cat already installed?
  3. #3 Re: Pros and cons of going catless
    Jun 2012
    Illinois
    No I was going to use the one that's in there already
  4. #4 Re: Pros and cons of going catless
    In the factory dp?
  5. #5 Re: Pros and cons of going catless
    Jun 2012
    Illinois
    Yeah I was going to make something up to keep the shell of the cat so it still looks like I have one
  6. #6 Re: Pros and cons of going catless
    just go catless it'll be some work for that to work and you could scrap it if its not gutted
  7. #7 Re: Pros and cons of going catless
    Jun 2012
    Illinois
    So pound out the inside and keep the dhell
  8. #8 Re: Pros and cons of going catless
    Willoughby, Ohio
    pros being catless = better flow, release more powaa. cons being catless = your exhaust smells worse, and you have to deal with the O2. when it comes down to it theres not much difference, its all in whatever helps you sleep at night
  9. #9 Re: Pros and cons of going catless
    no just don't use it at all
  10. #10 Re: Pros and cons of going catless
    Jun 2012
    Illinois
    Hmmmm thanks
  1. Debadging My 05 Black GXP pros/cons?
    By gagt3100 in forum Visual/Body Modifications
    Last Post: 07-09-2012, 07:27 PM
  2. Msd ignition - pros and cons please
    By LAST2DOOR in forum General Tech Discussion
    Last Post: 02-14-2012, 03:00 PM
  3. zzp pcm pros and cons
    By BlackGT97 in forum General Tech Discussion
    Last Post: 09-21-2011, 03:45 PM
  4. Pros and cons of GTP??
    By up in boost in forum Off Topic Discussion
    Last Post: 01-14-2010, 02:23 PM
  5. pros and cons
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 11:19 PM
