Thread: Want to make sure I'll be ok
Results 1 to 20 of 29
chris99gtp Want to make sure I'll be ok 07-21-2014, 10:20 PM
TwiztdWun Re: Want to make sure I'll be... 07-21-2014, 10:25 PM
chris99gtp Re: Want to make sure I'll be... 07-21-2014, 10:26 PM
ItHurtz Re: Want to make sure I'll be... 07-21-2014, 10:28 PM
TwiztdWun Re: Want to make sure I'll be... 07-21-2014, 10:28 PM
Slick2500 Re: Want to make sure I'll be... 07-21-2014, 10:38 PM
chris99gtp Re: Want to make sure I'll be... 07-21-2014, 10:40 PM
chris99gtp Re: Want to make sure I'll be... 07-21-2014, 11:31 PM
Slick2500 Re: Want to make sure I'll be... 07-21-2014, 11:33 PM
chris99gtp Re: Want to make sure I'll be... 07-22-2014, 01:39 PM
TwiztdWun Re: Want to make sure I'll be... 07-22-2014, 07:24 PM
chris99gtp Re: Want to make sure I'll be... 07-22-2014, 09:59 PM
ItHurtz Re: Want to make sure I'll be... 07-22-2014, 10:20 PM
TwiztdWun Re: Want to make sure I'll be... 07-22-2014, 10:28 PM
ItHurtz Re: Want to make sure I'll be... 07-22-2014, 10:32 PM
chris99gtp Re: Want to make sure I'll be... 07-23-2014, 10:31 PM
ItHurtz Re: Want to make sure I'll be... 07-23-2014, 10:44 PM
chris99gtp Re: Want to make sure I'll be... 07-24-2014, 08:26 AM
chris99gtp Re: Want to make sure I'll be... 07-24-2014, 08:07 PM
chris99gtp Re: Want to make sure I'll be... 07-25-2014, 04:43 PM
ItHurtz Re: Want to make sure I'll be... 07-25-2014, 11:03 PM
chris99gtp Re: Want to make sure I'll be... 07-25-2014, 11:04 PM
ItHurtz Re: Want to make sure I'll be... 07-25-2014, 11:06 PM
chris99gtp Re: Want to make sure I'll be... 07-25-2014, 11:07 PM
industrialfish Re: Want to make sure I'll be... 07-26-2014, 05:27 AM
chris99gtp Re: Want to make sure I'll be... 07-26-2014, 05:42 AM
industrialfish Re: Want to make sure I'll be... 07-26-2014, 10:06 PM
ItHurtz Re: Want to make sure I'll be... 07-26-2014, 02:32 PM
chris99gtp Re: Want to make sure I'll be... 07-26-2014, 10:07 PM
  1. #1 Want to make sure I'll be ok
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hello all,
    So through all my research, I want to make sure I'm on the right track. On sunday, SD headers are going on (thanks to corey for helping me out). I'm then going to drop to the 3.4. I will be able to scan with torque app to make sure i'm not getting a crazy amount of KR. I already have a slp catback, HAI, MPS and an Intesne PCM. I should be okay with the 3.4 and the intense PCM right? I've read some people drop to 104's and some not drop to them. What should i do about that and do i need to throw on a smaller belt? (658?) I've read some people are on the 3.4 with the stock sized belt. Also does the O2 defouler trick really work? or do i need get the code tuned out. I'm hoping to clear my cat out and keep the shell there just incase anyone has nosey eyes.
    Thanks a lot,
    Chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Want to make sure I'll be ok
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    I am running a 3.4 with no tune ( I wish I had one because I know there is more power and MPG to get out of it ), headers and 1.8's. You will need to go to a smaller belt....there is a thread on it that tells you the correct size somewhere. Both O2's and EGR are connected and I get no check engine lights. No other changes were made such as a non-fouler. I did however, remove my resonator and put a glass pack in place. I am also running the NGK version of the 104 plug. Can't remember the actual part number, but, your parts store can cross reference it over. I do remember my local AutoZone had to order them ,but, Advanced had them in stock.
    Official GPF Red Neck
  3. #3 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Oh and I heard that 3.4's run around 13.8-14.3? Is that true? I ran a 14.8 with bald tires
  4. #4 Re: Want to make sure I'll be ok
    Antioch, IL
    If your stock belt isnt super old you will be fine. I ran the stock belt. Anti fouler is up to your car if it works or not. Id run 104's but thats me, for a couple bucks a plug cant go wrong.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Want to make sure I'll be ok
    Feb 2013
    Ohio
    I have no clue. The only way I can see this setup getting you into the 13's would be if you put the car on a diet. Maybe I am wrong and a proper tune with a shift kit would get you there,but, I can not say for sure. Someone else may have more input on this.
  6. #6 Re: Want to make sure I'll be ok
    I think your basic 3.4 setup can get you into the low 14s high 13s.
  7. #7 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Would love to see 13s.... Even if it's a 13.99 lol
  8. #8 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    is there alot of people who've had good luck with the fouler? and i think i'm going to run the 104's, don't know about the belt yet
  9. #9 Re: Want to make sure I'll be ok
    Seems to work for a lot of people.
  10. #10 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    if i port the supercharger when i have it off when i change the LIM will i need to tune it then? Just the outlet.
  11. #11 Re: Want to make sure I'll be ok
    Feb 2013
    Ohio
    No. I forgot I ported my outlet as well. Tune is not necessary....but, you are leaving some HP on the table.
  12. #12 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Reuse the exhaust manifold gasket? And does the egr just bolt up to the header?
  13. #13 Re: Want to make sure I'll be ok
    Antioch, IL
    chris I told you already, if you dont mar the stock ones taking the manifolds off you can reuse them. egr should "bolt up" how I dont know never had one!
  14. #14 Re: Want to make sure I'll be ok
    Feb 2013
    Ohio
    In case you don't believe ITHURTZ...and I don't blame if you don't.....he is correct.
  15. #15 Re: Want to make sure I'll be ok
    Antioch, IL
  16. #16 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    just wanted to make sure! gotta drill out that egr plug and get it all ready for sunday. Hopefully going to be able to drop them in from the top. looks like i have enough room
  17. #17 Re: Want to make sure I'll be ok
    Antioch, IL
    ratchet the engine forward, should drop right in
  18. #18 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Hope it's as easy as you say lol
  19. #19 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    What size fouler would you guys suggest?
  20. #20 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Ive been reading up more on this going catless thing and have a question. Does the fouler trick only work with high flow cats? Or will it work catless too.
  1. How can I make this look better?
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 06-24-2013, 11:57 AM
  2. Can you make it through this?
    Last Post: 10-24-2011, 06:16 PM
  3. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  4. do they make these?
    By riceburner in forum Visual/Body Modifications
    Last Post: 12-01-2008, 10:13 AM
  5. This Will Make Your Day
    Last Post: 07-28-2008, 04:29 PM
