Thread: Want to make sure I'll be ok
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: Want to make sure I'll be ok
    Antioch, IL
    both, its a game to play on what works. I had to double stack the foulers on my last car to get it to work.
    2009 Challenger SRT8
    Expert at being gay.
  2. #2 Re: Want to make sure I'll be ok
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I'll quadruple stack it if that'll make it work!
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #3 Re: Want to make sure I'll be ok
    Antioch, IL
    Its easier to just get it tuned out
  4. #4 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    A lot cheaper this way tho... Lol you know I'm about that cheap route
  5. #5 Re: Want to make sure I'll be ok
    Oct 2011
    Toledo, OH
    Just my 4 cents, I had to use a washer to get my EGR to fit the SDs because it wouldn't bolt flush to the header IF you reuse your OEM gaskets. The SDs gaskets actually extend to the EGR tube to fill that gap.
    You should use both foulers anyway. One drilled to fit the sensor, one not.
    7"
  6. #6 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Drill it to be about a half an inch right? And then you leave the one that's closer to the exhaust the same?
  7. #7 Re: Want to make sure I'll be ok
    Oct 2011
    Toledo, OH
    Quote Originally Posted by chris99gtp View Post
    Yep. I bored mine to .500 and it fits perfect over the sensor. Undrilled one goes into the exhaust bung.
    7"
  8. #8 Re: Want to make sure I'll be ok
    Antioch, IL
    Ya, the one in the exhaust stream doesnt get touched.
  9. #9 Re: Want to make sure I'll be ok
    Jun 2012
    Illinois
    Sweet going to put them in tomorrow
  1. How can I make this look better?
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 06-24-2013, 11:57 AM
  2. Can you make it through this?
    Last Post: 10-24-2011, 06:16 PM
  3. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  4. do they make these?
    By riceburner in forum Visual/Body Modifications
    Last Post: 12-01-2008, 10:13 AM
  5. This Will Make Your Day
    Last Post: 07-28-2008, 04:29 PM
