Thread: replacing a headlight
Results 1 to 4 of 4
Jakegday replacing a headlight 12-23-2008, 11:11 AM
Iron Indian Re: replacing a headlight 12-23-2008, 02:54 PM
Jakegday Re: replacing a headlight 12-23-2008, 04:06 PM
Iron Indian Re: replacing a headlight 12-24-2008, 01:27 AM
  1. #1 replacing a headlight
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello, i tried searching and couldnt find anything, i was just wondering if someone could tell me how to replace a headlight on a 2001
  2. #2 Re: replacing a headlight
    Moore, Oklahoma
    Pretty easy and straight forward, theres x2 10 mm bolts on the headlight bracket under the hood, remove them and pull out the assembly toward the fender and it'll pop out, unplug the harness on the back side, now the assembly is out. From there you'll see how the housing bolts on, I believe its just a couple of bolts. The corner is held on by one bolt on the top side.
    Shawn W. Larsen
  3. #3 Re: replacing a headlight
    Nov 2008
    Fremont Nebraska
    well that was painfully simple
    thank yo u
  4. #4 Re: replacing a headlight
    Moore, Oklahoma
    Glad i could help
    Shawn W. Larsen
  1. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  2. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
  3. replacing LIM gaskets. HELP!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 06:22 PM
  4. Replacing the shifter cable
    By Zef_66 in forum General Tech Discussion
    Last Post: 01-25-2008, 01:12 PM
