Pretty easy and straight forward, theres x2 10 mm bolts on the headlight bracket under the hood, remove them and pull out the assembly toward the fender and it'll pop out, unplug the harness on the back side, now the assembly is out. From there you'll see how the housing bolts on, I believe its just a couple of bolts. The corner is held on by one bolt on the top side.
