Thread: Leaking gaskets need diagnosed (with pics)
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 201 to 220 of 228
  1. #201 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Did you discover it before or after the coolant started pouring out? hahahaha
    Before luckily I had just slipped the belt on glanced at my table and my elbows were still unopened in the box, my dad was pissed with the amount of dex that spilled on the floor.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  2. #202 Re: Leaking gaskets need diagnosed (with pics)
    Go to Walmart into the storage section. Get a 6" high long storage container that is about 18"-24" by 36". It's the worlds best catch pan. I have two. Use one for transmission service/oil change and one for coolant
  3. #203 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Dayton, OH
    I used to have one but it cracked worked really well for trans pan drops. Just don't drop any bolts...
    2012 F150 STX
  4. #204 Re: Leaking gaskets need diagnosed (with pics)
    I drop stuff. You need the right tools.
    http://www.ebay.com/itm/Microflex-MF..._Tools&vxp=mtr
  5. #205 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    How high up to I fill rad after its bled?
    Sent from my SCH-I545 using Tapatalk
  6. #206 Re: Leaking gaskets need diagnosed (with pics)
    to the top, then cap it.
  7. #207 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Operating coolant temp of 205 is pretty normal right?
  8. #208 Re: Leaking gaskets need diagnosed (with pics)
    yes. idling or in traffic. may come down on the highway.
    this was mine a few weeks back during a hot ass day.
  9. #209 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Wow. So it looks like I still get a drip of oil after running. Must be oil pan but I'm not gonna worry about it. Hopefully the LIM gaskets hold up
  10. #210 Re: Leaking gaskets need diagnosed (with pics)
    im sure the lim is fine.
    if you have car ramps drive up on them and spray the under side with de greaser then wash it down. park over card board for the next few days so you can trace the leak up, then follow the wet spot up.
    you can also ramp it, and spray it down with brake cleaner then wipe it down, and watch it over the next few days too.
  11. #211 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    P1676 code? Something involving the evap???
  12. #212 Re: Leaking gaskets need diagnosed (with pics)
    http://www.gmforum.com/obd-ii-troubl.../p1676-284196/
    you sure its plugged back in? code is for low voltage to the evap purge solenoid, you took that off and put it back on, the one with two vac lines on the back of the sc.
  13. #213 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Yea , both lines are plugged in.
  14. #214 Re: Leaking gaskets need diagnosed (with pics)
    the electrical plug i mean lol
    theres a plug for it laying back there somewhere if you haven't plugged it back in. map has a plug too.
  15. #215 Re: Leaking gaskets need diagnosed (with pics)
    The plug is red.
    On that oil drip. Let it be. Most likely on a 3800, it's the rear engine cover (not rear main seal) and .. to do that cover gasket, you'd have to pull the engine or trans. I say ... let it drip once a day and wipe the pan off when you do oil changes.
  16. #216 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Update: Today the low coolant light came on. Not totally sure why, Im hoping its not leaking somewhere and that as Ive been driving it its just been getting spread throughout the engine. I guess I will add what is left of my 50/50 mix and hope for the best
  17. #217 Re: Leaking gaskets need diagnosed (with pics)
    is the rad low? if its full your low coolant sensor is either dirty or dead. unplugging it turns the light off if its full.
  18. #218 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    I'll take a look once the engine cools. Light has never came on before
  19. #219 Re: Leaking gaskets need diagnosed (with pics)
    the sensor is on the pass side of the rad, its got a clip that holds it in the rad, then it pulls out. you can try cleaning it if the rad is full, dex can make it dirty.
    you can see it good with the pass side head light out, at least on my regal i can. thats how i unplugged mine when it lit up full time with full coolant.
  20. #220 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Coolant level was low. Filled it back up to the top I still have a little under a half gallon of 50/50 mix remaining so Im not sure if its leaking or what
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
