Thread: Leaking gaskets need diagnosed (with pics)
Page 1 of 12 12311 ... LastLast
Results 1 to 20 of 228
  1. #1 Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Hey guys, I was just checking up on my engine bay with a LED flashlight in order to locate any leak spots. I found a couple and one that I would like someone to tell me what gasket it is thats leaking. The first picture I believe to be the valve covers.
    This next picture I need help diagnosing. Thanks!
    Sent from my SCH-I545 using Tapatalk
  2. #2 Re: Leaking gaskets need diagnosed (with pics)
    First is the valve cover, correct.
    The second just looks like a very very minor seep from the trans case gasket. I bet if you cleaned that one, it wouldnt look like that for another year or even a few years. It just looks worse because the dirt has stuck to it and built up.
  3. #3 Re: Leaking gaskets need diagnosed (with pics)
    First I could see being valve cover or lower intake gaskets. The second, we can see seepage coming in from out of the view. This could be the LIM gasket, could be the turn around on the end of the LIM, and it could be a trans casing seepage.
    Trans seepage is not very likely in this area, although a little fluid may have flung up and found the breather hole of the trans. I'm doubtful that it's trans. And if you are paranoid and go check your trans fluid..I bet it's not 100% filled..but that's normal.
  4. #4 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2014
    CT
    I agree follow that seepage off to the left from second pic. Take your air cleaner off then look under the lower intake manifold. That's where mine was leaking oil.
  5. #5 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok thanks guys. Im gonna go ahead and replace my LIM gasket, SC gasket, and valve covers. I watched a video on YouTube about the LIM replacement but Im still not too confident. Is it a tough job for a rookie? I feel like if I can just get the SC then it would be easy from there.
  6. #6 Re: Leaking gaskets need diagnosed (with pics)
    Doing this job is turning bolts counter clockwise to loosen, cleaning parts and tightening bolts by turning them clockwise. If you look at one bolt at a time instead of the big picture, it'll look and be easy.
    If you let yourself get overwhelmed by the large picture, pop back on the forum. There's nothing we can't help with.
  7. #7 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Awesome! sounds great, thanks!
  8. #8 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    From reading some write ups and watching videos, some people remove a couple of pullies but I don't see how that is necessary. Is that a must?
  9. #9 Re: Leaking gaskets need diagnosed (with pics)
    The only pulley you would have to remove is one on the SC tensioner to be able to remove the black bracket that overhangs the valve cover.
  10. #10 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Would these plugs need to be removed that connect to the fuel rails?
  11. #11 Re: Leaking gaskets need diagnosed (with pics)
    nope. only if you are removing the fuel rail. valve cover removal they stay put.
  12. #12 Re: Leaking gaskets need diagnosed (with pics)
    oh, and de grease your engine before working on it, the day before. working on a clean engine is much nicer.
  13. #13 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    I thought I needed to move the fuel rail though. Its not just the valve covers im doing but also the LIM. And yeah I will degrease it and probably gonna clean everything up real nice while I have it off the car.
  14. #14 Re: Leaking gaskets need diagnosed (with pics)
    no, clean it first, then do the lim job. every plug you see will need to come off to do the lim, off the TB and lim, and injectors, the map and evap, the boost by pass solenoid. the alt, take it off too. and the vac lines.
  15. #15 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok so then the plug in the picture will need to be removed correct? That was the only one I was unsure of
  16. #16 Re: Leaking gaskets need diagnosed (with pics)
    yes unplug the injectors, un bolt the 4 corners of the rail and then pull up on the rail, the injectors will pull from the heads.
    you can flip the rail to the side, or take the lines off the rail with a quick disconnect tool.
  17. #17 Re: Leaking gaskets need diagnosed (with pics)
    Whoa.. lemme lay this out a bit more straight forward. The vid has a lot extra in it.
    You want to
    Disconnect negative battery cable (move it away from battery where it connects so it can't reconnect itself gently)
    Remove alt
    Disconnect three sensors on throttle body
    Disconnect electrical on front of super charger by throttle body (that's called the boost soleniod)
    Disconnect the EGR electrical by the back side of the TB
    Disconnect the 6 fuel injectors by pushing that wire toward the injector and pulling up... that releases it's clip w/o removing the wire clip itself
    Disconnect the 1 connector on the MAP sensor (behind supercharger by bracket from alt to SC)
    Drain coolant
    Lift fuel rail out of way (4 10mm nuts at corners of rail, plus 1 13mm bolt on top of sc) If you don't have a fuel line tool..gently lay the rail out of the way.
    Remove supercharger (yes the EGR shield also needs to come off to get the SC unbolted)
    Good time to unbolt and clean the throttle body
    Remove 3 bolts holding the alt bracket to the engine (this is the bracket it sits on) You may need to wiggle/gently coax to get the coolant elbows to release)
    Remove LIM (12 3/8" bolts, I mention that because when you go to torque them..10mm socket will spin)
    Clean and let's reassemble
    LIM bolts get a little loctite or liquid teflon with ptfe to seal them, torque to 15ft lbs on metal LIM gaskets, 13 ft lbs on plastic gaskets
    SC bolts are 17ft lbs.
    Everything else is...reasonable. Don't try to kill all the bolts. Some are smaller and can't take it.
  18. #18 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Bill, thanks alot for that helpful write up. I went through and understood a majority of it while looking at my car and the only things I was not able to locate were the EGR and the MAP. Is this the MAP?
  19. #19 Re: Leaking gaskets need diagnosed (with pics)
    Ooops..forgot to tell you to take the evap off. That's evap. Map is down below that and a smidge more to the driverside. It's also bolted to the SC. EGR is that big thing with connector on top right behind the TB towards the firewall.
  20. #20 Re: Leaking gaskets need diagnosed (with pics)
    those are pinch and pull ends on the evap solenoid iirc.
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
