Thread: A/C PRO recharge kits
Results 1 to 19 of 19
  1. #1 A/C PRO recharge kits
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    It is finally warming up here in MN and we can put an end to the Brrrrr!! thread. Has anyone used the A/C Pro recharge kits? I see ads on tv and the kits are in current Auto Parts sale fliers.
    http://www.youtube.com/watch?v=Wn0C9jPOAAQ
    http://shop.advanceautoparts.com/p/a...rchTerm=ac+pro
    Thanks.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: A/C PRO recharge kits
    Jan 2014
    AR
    Quote Originally Posted by Madness View Post
    Thanks.
    I have used that stuff on two cars and been pleased with the results.
  3. #3 Re: A/C PRO recharge kits
    I think I used the Ez Chill stuff.
  4. #4 Re: A/C PRO recharge kits
    Dec 2008
    Lawndale, CA
    I just used it on mine and it worked fine.
  5. #5 Re: A/C PRO recharge kits
    I use the cheapest cans of r134a I can find. I just got some for $5 a can. It all works the same. If you have to add to your system though you have a leak somewhere
  6. #6 Re: A/C PRO recharge kits
    Feb 2013
    37.295091, -121.930053
    best bet your low side port valve but yeah all 134a is the same. I love fixing ac systems its so freaking easy
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: A/C PRO recharge kits
    Pennsylvania, USA
    If you suspect a leak, get some refrigerant dye and put a few drops in the end of the connector before hooking it up. If it starts getting warm again, you can use a black light to spot where it's leaking. Check with a black light before you try though, you may need to rinse the lines and stuff down as other things can glow under the light.
    Those things work great as long as the leak is small, it kept my 05's AC running by adding a can once a year, but don't bother with any that contains stop leak. It shouldn't do any harm, but it won't stop any leaks.
    Now if you want like, as cold as when the car was new, just buy a gauge set from Harbor Freight (they're pretty cheap) and rent a vacuum pump. You can do a professional evacuation and recharge surprisingly easy.
    This dude shows how easy it is. As long as you use the correct weight of refrigerant, nothing will get you colder AC than that. Replacing the accumulator wouldn't hurt either.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  8. #8 Re: A/C PRO recharge kits
    Apr 2014
    CT
    I have a few comments on that video. first of all if you want to do it yourself just wait for an 80+ degree day. The rule of thumb with high side pressures that will get you in the ball park is 2.5 times ambient temperature at 1500 rpms ( so yes you need to give it a little throttle). so its 80 degrees out. 2.5 x 80 = 200. your high side pressure should sit somewhere around 200 psi. However what many people overlook is make sure the radiator fans are working properly! if the heat is not drawn from the condenser the high side pressure will skyrocket even though it technically has a low charge. On some rear wheel drive vehicles with clutched fans the clutch may start failing enough to affect the ac performance.
    Low pressure especially the ones like on the GP's compressor is variable and the low pressure gauge only wont tell you squat. It will only tell you when you have enough refrigerant to satisfy the low side but you need to add more to get the high side at the right pressure.
    If you fill with liquid ( turning can upside down during fill) make sure to never let the low side pressure go above 50 psi because if liquid gets into the compressor it will instantly kill it. On the gp I believe the low ports are far from the compressors so there isn't much of a worry but I have worked on cars the low side is right at the compressor.
    im not sure where this guy gets the info of using low fan speed. I was taught to use the highest setting without recirc and the windows open. Maybe he was using low fan speed because the ambient temp was down.
  9. #9 Re: A/C PRO recharge kits
    Apr 2014
    CT
    its easy till you have to deal with black death
  10. #10 Re: A/C PRO recharge kits
    Quote Originally Posted by paedbo View Post
    Black death?
  11. #11 Re: A/C PRO recharge kits
    Feb 2013
    your talking about when you mix r12 with r134a yeah it makes a black sludge and kills the compressor.
    EDIT: its the oils from r12 and 134a mix and make it
  12. #12 Re: A/C PRO recharge kits
    Pennsylvania, USA
    Thanks for the info paedbo, I just learned some useful info! I'm doing basically an AC overhaul later this month, so I'll definitely keep all that in mind.
    Can't wait for some ice cold, reliable AC, I haven't experienced that since I got my 05 used three years ago
  13. #13 Re: A/C PRO recharge kits
    Apr 2014
    CT
    theres a product I like to use on o rings too called nylog look it up
  14. #14 Re: A/C PRO recharge kits
    Pennsylvania, USA
    Nylog, I've never heard of the stuff. Definitely can't hurt, I'll be replacing just about every o-ring anyways. I'm going to guess you've done quite a bit of AC work
  15. #15 Re: A/C PRO recharge kits
    Apr 2014
    CT
  16. #16 Re: A/C PRO recharge kits
    Apr 2014
    CT
    don't have to necessarily mix oils. poor lubrication, and on compressors like the fx15 the Teflon rings disintegrate turning into a fine powder. Mixed with hot oil and refrigerant and tada! Black death caked all over everything. No use trying to flush. You may be able to save the evaporator otherwise its a firewall forward replacement of everything. Put a new compressor back in a system that suffered black death and it will not survive long either.
    Nik -12937 blue nylog by the way. red is is harder to work with. Btw I am a licensed mvac technician all though I haven't worked in the field for a long time.
    here's another interesting thing I found I have not used this product tho.
    http://www.ebay.com/itm/R134-A-C-Ref...e4ae0b&vxp=mtr
  17. #17 Re: A/C PRO recharge kits
    Pennsylvania, USA
    I had a sneaking suspicion you were, a majority of people (including me) have a pretty limited knowledge of AC systems past their basic design.
    I'll just order some tomorrow to make sure I don't mix them up, it's pretty cheap for how helpful it could wind up being.
    I think I'll test out those oil checkers too while I'm at it, can't argue with $7.50 after shipping. I know for a fact my system is pretty done at the moment, though it still works for a week or so if you add some freeon, so I can test one knowing it should come up bad. Another tool to make sure I get the system as close to its condition out of the factory. Not having AC is actually even crappier in the winter months (in my opinion) while living in PA. I can stand pretty hot temperatures without much complaint, but it's so difficult to defog the windows in cold weather without a functioning compressor.
  18. #18 Re: A/C PRO recharge kits
    Apr 2014
    CT
    let me know how the pittstop oil checker works.
  19. #19 Re: A/C PRO recharge kits
    Quote Originally Posted by nik12937 View Post
    The compressor doesn't run if it's under 36° anyway
  1. A/C Warm after recharge - Too much oil?
    By Matticus in forum General Tech Discussion
    Last Post: 06-11-2013, 06:00 PM
  2. AC recharge??
    By apierce1289 in forum General Tech Discussion
    Last Post: 08-14-2011, 10:07 AM
  3. A/C Refrigerant Recharge
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-10-2011, 12:59 PM
  4. AC Recharge
    By dreyescairo in forum General Tech Discussion
    Last Post: 08-25-2010, 07:34 AM
  5. AC Recharge Question
    By dmontgom in forum General Tech Discussion
    Last Post: 05-02-2009, 06:54 PM
