Thread: Unknown Hose!!!!!
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Unknown Hose!!!!!
    My mistake thinking NY was NYC.
    Scott is suggesting things to determine if the issue is the fans, the engine, or the driver. If you follow his suggestions (which would be nearly the same from most of us) then you'll have the issue resolved quickly. If you post instead of try stuff, well... then nothing actually gets corrected.
  2. #22 Re: Unknown Hose!!!!!
    Sep 2012
    Cedar Rapids, Iowa
    You can check the water pump by taking off the serpentine belt and spinning the pulley on the water pump, if it has any play in it is time for a new one. Shoulda just replaced that while you were doing the coolant elbows. They're relatively inexpensive depending on where you buy them.
  3. #23 Re: Unknown Hose!!!!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You might have air I the cooling system from doing the elbows
    This if you didn't bleed the system and add coolant after the elbows.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #24 Re: Unknown Hose!!!!!
    GT Level Member thegipper's Avatar
    grafton, wi
    This.
    You need to start testing some stuff out. If your fans are turning on when you turn on the A/C you can eliminate that.
    You probably have air in the system from when you replaced the elbow. If you haven't properly bleed the air out of your system, I would start there. That is most likely your problem. If not, I would check the water pump next.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  5. #25 Re: Unknown Hose!!!!!
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Basically he is explaining how to test your cooling fans. (By turning the ac on). It could also be air in the system. My personal favorite method is to remove the thermostat housing. Dump coolant in there until the engine is full. Put it back together. Fill the radiator. Replace the rad cap with a new one. Run it the burp out the rest..... Im sure there is some fancy offcial way to do it but that method has worked for me many a time.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  6. #26 Re: Unknown Hose!!!!!
    SE Level Member Pontiacmaster81's Avatar
    Jan 2014
    New York
    Quote Originally Posted by MattF View Post
    Yes it was my stupid water pump. Water Pumps fail with some regularity--you can expect to replace yours sometime before 100,000 miles
    Like my Coolant Elbow the thing was left un cared for and it sits at 167,000 miles for an 02. Thanks again everyone for the awesome help
    2002 PONTIAC GRAND PRIX GT
    "LISTEN! CAN YOU TELL THE DIFFERENCE BETWEEN
    A CAR WITH A BAD TRANSMISSION, AND ONE THAT IS POSSESSED BY A DEMON FROM HELL?"
  7. #27 Re: Unknown Hose!!!!!
    My water pump went around 189K miles. It really depends on how much error was built into it.
  8. #28 Re: Unknown Hose!!!!!
    Jan 2014
    New York
    CIMG6480.jpgNew Coolant Elbow and Water Pump, It was a pain getting the Coolant Elbow out and had to take the entire Power steering pump out to get it out, and when I did I noticed the issue. The plastic Elbow was completely in 4 pieces cracked and even burned. It took me 3 hours to get it off and back on because of the stupid Pieces stuck inside. Thanks though for the help
  9. #29 Re: Unknown Hose!!!!!
    Apr 2012
    Dayton, OH
    You did it the hard way, I just used a pick and it came right out.
    2012 F150 STX
  10. #30 Re: Unknown Hose!!!!!
    ive gotten a lot of miles out of my cheap 2 dollar pick set. pulling broken elbow out was one job it did well.
  11. #31 Re: Unknown Hose!!!!!
    Jan 2014
    New York
    Yeah Russ there was 4 Screws I did not see until it was completely over, But lesson learn though
  1. Unknown issue
    By mrdbaby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2013, 06:08 PM
  2. unknown part
    By Tareksalem in forum General Grand Prix Discussion
    Last Post: 06-13-2013, 01:18 PM
  3. Unknown component
    By terrellc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2012, 01:24 AM
  4. Unknown Noise
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 05-07-2012, 08:49 AM
  5. Unknown Rattling
    By Michael Cosby in forum General Tech Discussion
    Last Post: 04-06-2012, 08:37 AM
