This.
You need to start testing some stuff out. If your fans are turning on when you turn on the A/C you can eliminate that.
You probably have air in the system from when you replaced the elbow. If you haven't properly bleed the air out of your system, I would start there. That is most likely your problem. If not, I would check the water pump next.
