Thread: Radiator Fan Not Working
Results 1 to 7 of 7
  1. #1 Radiator Fan Not Working
    Jul 2013
    United States
    I own a '99 gtp and I realized about a month ago when it started to warm up that my radiator fan was no longer working, and looking back I think it has been broken for a few years now. So I decided to replace the entire assembly...no luck. I then replaced the three relays involved with the fan as well, also no luck. Fuses were all fine too. I went back and made sure the connectors were properly in place as well and they were fine. Any ideas?
  2. #2 Re: Radiator Fan Not Working
    Feb 2013
    37.295091, -121.930053
    try turning the ac on. if it works with that then its a ground. or could be motor but try ac first
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Radiator Fan Not Working
    Howell, NJ
    The radiator fans don't kick on until the coolant reaches some ridiculous temp around 220 or so.
    I think unplugging the coolant temp sensor turns them on. Try that. If that works, then congratulations your car isn't over heating.
    Sent from my DROID RAZR using Tapatalk
  4. #4 Re: Radiator Fan Not Working
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Jomamma View Post
    This.. Easiest check to see if the system has an electrical issue.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #5 Re: Radiator Fan Not Working
    yup, fans wont come on till 212, 220 something is high speed.
    if turning the a/c on does not turn the fans on instantly, unplug the temp sensor if the fans just run full time now your temp sensor is bad.
  6. #6 Re: Radiator Fan Not Working
    Jul 2013
    United States
    I know they don't kick on until 215 or so but since I've replaced it it has almost overheated a couple times, with or without the A/C on. I'll try removing the sensor and see if it turns on.
  7. #7 Re: Radiator Fan Not Working
    dont remove it, just unplug it, it underneath the t stat housing on the lim.
    if you take it out coolant will leak out.
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. Radiator fans not working
    By Paul Hagensick in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-18-2012, 08:25 PM
  3. radiator fans not working
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 07:59 PM
  4. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
  5. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
