Thread: Key Cylinder LOCKED bad, Not the normal issues.Help
Results 1 to 3 of 3
  1. #1 Key Cylinder LOCKED bad, Not the normal issues.Help
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    OK so i had issue with the key cylinder was locked in the on position a few days a go. I was able to pop the cylinder out and heard some metal fly but didn't think much of it and put the cylinder back in and seemed to work better but not any key will turn it. i was thinking i got a upgrade but then when at store today the cylinder locked out bad. in the off position. key comes in and out no problem but i cant turn it. tried to pop cylinder out again but since its locked in the off position and wont turn i cant get to the release position again. I not sure what i should do next. I think i will drill out the cylinder and try to get it out because a new cylinder is only like $25. Im hoping someone will have some better options I have added a picture to show what piece of metal i found later on my floor from cylinder. Help please. THANKS
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  2. #2 Re: Key Cylinder LOCKED bad, Not the normal issues.Help
    Apr 2014
    Chicopee,MA
    update: Fixed
  3. #3 Re: Key Cylinder LOCKED bad, Not the normal issues.Help
    Apr 2014
    Chicopee,MA
  1. Intermittent Misfire cylinder #1 issues
    By rcdino1978 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-19-2011, 11:31 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  4. normal performance issues
    By masterkevj in forum General Tech Discussion
    Last Post: 03-09-2010, 09:36 PM
  5. Suggestions Needed: L32 cylinder head issues
    By Angelo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2009, 06:55 PM
