Originally Posted by BillBoost37 Pull off the TB and clean it. If that doesn't fix the issue, unplug the maf and see if it seems better. Originally Posted by BillBoost37 Turn over/cranks - engine spins when starter is engaged Starts - engine fires up and runs on it's own Originally Posted by BillBoost37 Throttle body - start there. Then the maf is the mass airflow sensor. It is connected to the pcm via a connector and wiring. Thank you , I will look up those two thing and start there .
Forum Rules
