Thread: Help please
Results 1 to 18 of 18
  1. #1 Help please
    Nov 2013
    Las vegas
    Ok I have a 06 Grand Prix v6 no turbo and yesterday my lady was driving and at the light the car just stalled out when I try to start it just jugs and won't turn over , it has done this before but it would always turnover on the second try, I don't think it would be starter because it just stalled out at light all my fluids have been kept up really good I don't no maybe CPS?? Need some help please
  2. #2 Re: Help please
    Nov 2013
    Las vegas
    The car also has been shaking really bad upon acceleration , maybe timing chain or just timing I'm lost
  3. #3 Re: Help please
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    not sure what jugs means? so does it turn over? no? just click? why did it stall... is there a SES light? how many miles? you say its been shaking bad open acceleration? steering wheel/wheel bearing/unbalanced-lumpy tire? or engine vibrations/chugging? if engine chugging is going on do you have good fuel presure?
    Need more info to help bud.
  4. #4 Re: Help please
    Pull off the TB and clean it. If that doesn't fix the issue, unplug the maf and see if it seems better.
  5. #5 Re: Help please
    Nov 2013
    Las vegas
    Quote Originally Posted by RedneckGTP View Post
    Sorry I ment chuggs , it won't turn over it sounds like it want to turn over almost like if you were out of gas .car had been driving fine other then the really bad shaking upon acceleration , when I let off gas shaking stops, I got brand new tires on it
  6. #6 Re: Help please
    Turn over/cranks - engine spins when starter is engaged
    Starts - engine fires up and runs on it's own
  7. #7 Re: Help please
    Nov 2013
    Las vegas
    What is a tb???unplug the maf??sorry I don't understand ?
  8. #8 Re: Help please
    Throttle body - start there.
    Then the maf is the mass airflow sensor. It is connected to the pcm via a connector and wiring.
  9. #9 Re: Help please
    Nov 2013
    Las vegas
    That sounds like what is happening the engine is spinning but not firing , what would be causing this, Timming chain, CPS ???
  10. #10 Re: Help please
    Nov 2013
    Las vegas
    Thank you , I will look up those two thing and start there .
  11. #11 Re: Help please
    Aug 2011
    'Merica
    Does it start when the car is cold? Does it start this issue after the car is warmed up?
  12. #12 Re: Help please
    Nov 2013
    Las vegas
    Quote Originally Posted by Below Average Joe View Post
    No only on cold start and then this time when driving ? And I tried to start it today and nothing
  13. #13 Re: Help please
    Aug 2013
    arlington, tx
    TB and MAF would be a good place to start
  14. #14 Re: Help please
    Nov 2013
    Las vegas
    Quote Originally Posted by luckyg817 View Post
    Ok we'll I got it to start by messing with the TB, but then the engine light came on and said reduced power.. Should I take the TB Apart and clean it seemed to be stuck 1/3 open .
  15. #15 Re: Help please
    Aug 2013
    arlington, tx
    Quote Originally Posted by Tone5500 View Post
    Yes, as fordman said, clean both sides of the butterfly plate and then what I have done is take a clean rag and spray it down with some TB cleaner and cleaned the inside of the plenum. Just reach in there and wipe down as much as you can but don't spray directly into the plenum, just onto the rag. See if the symptoms go away. If not, you can at least eliminate those 2 options. As far as the CEL and reduced power message, make sure you hooked up the connector to the TB correctly and make sure your MAF sensor is completely dry before you install it again. I had the same thing happen to me and after freaking out and turning the car on and off a few times, it went away on its own.
  16. #16 Re: Help please
    St. Louis
    Yes, as Bill stated, remove the entire TB from the intake, clean the thing until it shines inside (both sides of the butterfly) and reinstall. The drive-by-wire setups like to get carbon buildup on them and do all kinds of weird things. If you plan on cleaning the MAF as well, be sure to get some approved MAF cleaner (don't use brake or carb cleaner on it).
  17. #17 Re: Help please
    crank sensor anyone? ever see the tack drop to zero before it stalls?
  18. #18 Re: Help please
    Symptons don't fit yet Scottydogger.
