Thread: Crazy Electrical issues
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #1 Re: Crazy Electrical issues
    GT Level Member Exile's Avatar
    Chicago
    Got my EBCM module removed. The four/five indicators have quit flickering and now are just solid (abs & tcs off)...which I call an improvement lol. Shift indicator, low trac, clock aren't flickering with it removed.
    Now just to decide on who I'm shipping it to for repairs. Modulemaster is likely but there's a few on ebay for $60 less or so. Might try to find someone local to Chicago, idk if any of you know someone perhaps ??
    And 02Navy, I did check the big ground by the battery. Didn't remove it, but its not lose or anything. There's one infront of the radiator that seems ok too. Any others I should locate?
    Well grounds is an easy place to start. They get rusty. The way I mentioned cleaning them makes it better than how it came.
    2001 Black GTP Special Edition
    KYB Excel-G struts, Dorman & GMPP swaybars, Dorman/WBS trailing arms, K&N CAI, ZZP 3" DP, Thrush GP, all new calipers
    And the GP appropriate gas cap fender rust
  2. #2 Re: Crazy Electrical issues
    Dec 2012
    Where 4T65E's were born
    You have to remove it to inspect it. Rust forms between the washer and ring terminal, and in the threads of the bolt.
    Sold.
  3. #3 Re: Crazy Electrical issues
    hangover park IL
    they love to snap off, welcome to the rust belt
    ps a new ground from battery strung over and connected to it really does help.
    id suggest checking the HL grounds too. usually gives ya a hair brighter ****ty GP lighting
    ~James~ Psychotic Gearhead
  4. #4 Re: Crazy Electrical issues
    Chicago
    Spent a couple hours checking and cleaning all the grounds. Also removed the rubber boots for both battery connectors and cleaned them good with baking soda & wire brush dremel bit. The negative connector was one quarter covered in corrosion. Here are the grounds i found and cleaned..
    - next to battery
    - on tranny case (one thick wire, one smaller wire at same post)
    - on engine by belt/idler
    - headlight ground
    Did I miss any? None of them were lose or severely corroded. Still cleaned them all anyways.
    Nothing has changed, alarm/rs system still not working properly at all. Battery backup alarm now gets triggered everytime you turn on the headlights (new since removing ebcm). Probably going to have it all ripped out... only five years old tho sigh.
    Kind of NEED keyless entry tho, this car has intermittently had the key stuck in ignition problem for five years now. Never been a concern since it has the remotes/alarm.
  5. #5 Re: Crazy Electrical issues
    Dec 2012
    ^ I second that, just remove the dang thing. You listed the main grounds so that's taken care of, unless it's the grounds for those specific circuits I say remove the thing.
    Sold.
  6. #6 Re: Crazy Electrical issues
    Chicago
    UPDATE:
    Received my rebuilt ebcm and installed it yesterday. Lights don't go thru a flashing pattern or automatically stay lite upon start up. No more relay rapidly actuating from the ebcm unit either. 5-10min after driving both abs and tcs off lights do come on tho.........! Scanned it, C0036 - (L F Wheel speed circuit range/perf) & C0035 (L F Wheel speed sensor circuit malfunction). I guess Timken hubs only last so long too. Fixed one thing just so that thing could tell me what else is not working properly lol. Silly question... does "Left Front" mean driver side or passenger?
    As for the alarm/rs, I've just quit using it. Unplugged most of the connectors from the 'security brain'. Plan to play around with the cables a little in hopes to restore lock/unlock.... that's all I want. Otherwise there's plenty of Audi/Mercs in my neighborhood to get stolen before my pos haha.
  7. #7 Re: Crazy Electrical issues
    SWPA
    Left front is drivers.
  8. #8 Re: Crazy Electrical issues
    left front should mean driver side front.
  9. #9 Re: Crazy Electrical issues
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Double check that its the WSS and not possible broken wires from the hub to EBTCM. Could save you 80 bucks.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  10. #10 Re: Crazy Electrical issues
    Chicago
    Yea definitely will be looking at the wires and checking the connection before I jump on another $100 hub. Driver rear needs to be done too (lots of play/wobble). Been an expensive month for this car. Rebuild was $200 with shipping.
  11. #11 Re: Crazy Electrical issues
    Apr 2012
    Dayton, OH
    Ouch
    2012 F150 STX
  12. #12 Re: Crazy Electrical issues
    Chicago
    Interesting update...
    The alarm/rs system is working again. Finally went the other day to messing with the security brain connectors to see if i could at least get keyless entry. That worked right away, along with both sirens. Plugged the RS connector back in, hit the remote, VROOM started first crank. Been using it everyday fine for a week now.
    Maybe the ebcm was so jacked up it was sending stray electrical signals all over to places it shouldn't causing the alarm system to go haywire. What's weird is the alarm didn't work right when the ebcm was removed for shipping. I know the RS requires a reading from the tach, but its not like the tach is tied to the ebcm..right?
    And as for the abs sensor, I just reseated the connector and tugged on the wires. The lights haven't come back on for a few weeks. Probably temporary, guessing the pigtail will have to be replaced soon.
    Now i'm annoyed i put scratches on my driver door after using the key for the last month lol.... dam car.
  1. Help! Electrical issues!
    By mrfreez in forum General Tech Discussion
    Last Post: 04-13-2013, 10:36 AM
  2. electrical issues
    By toastisdead in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2012, 10:44 PM
  3. Car issues - electrical and key
    By JJ133169 in forum General Tech Discussion
    Last Post: 06-20-2011, 07:20 PM
  4. possible electrical issues
    By jcmonteman in forum General Tech Discussion
    Last Post: 04-18-2011, 05:47 PM
  5. Electrical Issues.
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 11:59 AM
