Thread: Internal Wastegate Turbo on GTP?
Results 1 to 2 of 2
  1. #1 Internal Wastegate Turbo on GTP?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    As I consider a turbo build for the GTP, been wondering if it is an acceptable plan to use front and rear PLOGs, Z3 crossover (no wastegate purge) and then use an internally wastegated turbo.
    Parts would be a bit cheaper, but I am not familiar with internally gated turbos that will flow enough for the demands of the GTP.
    Let me know what you think! open to any suggestions.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Internal Wastegate Turbo on GTP?
    Feb 2009
    flintnasty MI
    Sounds fine. Zzp sold a few gm46 turbo kits that ran like mules.
  1. Does the turbo wastegate pipe need to route under the car?
    By traildog in forum General Tech Discussion
    Last Post: 01-19-2014, 01:30 PM
  2. wastegate actuator
    By kawasakidrivinghick in forum Wanted To Buy - Parts
    Last Post: 02-19-2013, 05:18 PM
  3. Wastegate prob.
    By 420in713 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 11:51 AM
  4. Wastegate
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-18-2009, 04:31 PM
