Thread: need help choosing a cam
Results 1 to 15 of 15
  1. #1 need help choosing a cam
    Nov 2012
    pistolvania
    i just purchased a 30,000 mile l67 off of craigslist i want to change the gaskets and cam it . just not sure which cam i want. it has to be street able not have to do headwork and if possible not have to change spring or retainers which would lean me towards the vs but i do want to have a nice sounding idle which pushes me towards the xp or slx . also would like to still keep decent gas mileage.....so basically i have no idea what i want someone nudge me in the right direction. it is going in a 99 gt with the gt trans some speed daddy headers and a canned tune (of which i also don't know who to use advice would be appreciated)..........also last but not least it will have 22 inch rims if it matters (let the hate commence)
  2. #2 Re: need help choosing a cam
    Any cam is going to require replacement of the stock springs. Even the VS after maybe 6 months will wear out the stock valve springs.
    I would go XP or S1x both are about the same and are pretty streetable, get some 105# springs and new retainers. A 30k mile timing chain should be okay for now but I would at least replace the tensioner.
    As far as canned tune I would talk to Will @ overkill performance I have heard nothing but good things about his tunes.
    22 inch rims = your trans is going to hate you.
  3. #3 Re: need help choosing a cam
    Nov 2012
    pistolvania
    okay xp or slx... will at overkill 105# SPRINGS Retainer tensioner ....would you use the zzp cam install kit and if so which one or would you piece it together from like ebay or something ...and last anything else you would check replace while your in there...
  4. #4 Re: need help choosing a cam
    Kind of neglecting the purpose of camming it if your going to run heavy rims.
    04 Comp G.
  5. #5 Re: need help choosing a cam
    Go for kit 2, it comes with the timing chain dampener, I know I said tensioner but that is what meant, and buy the Fel Pro Valve cover gaskets. ZZPs valve cover gaskets have been known to leak.
  6. #6 Re: need help choosing a cam
    You mean negating?
  7. #7 Re: need help choosing a cam
    Autocorrect >_<
    Einstein
    04 Comp G.
  8. #8 Re: need help choosing a cam
    Nov 2012
    pistolvania
    it looks mean with the rims tho
  9. #9 Re: need help choosing a cam
    Nov 2011
    NY
    Quote Originally Posted by lance4682 View Post
    looks like there should be a few horses strapped to the front pulling it.
    lol
    just not my cup of tea, but if it floats your boat, I say enjoy it : )
  10. #10 Re: need help choosing a cam
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    With those wheels add a trans cooler to your list along with whatever cam you get.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  11. #11 Re: need help choosing a cam
    Nov 2012
    pistolvania
    any recommendation on a trans cooler
  12. #12 Re: need help choosing a cam
    Nov 2011
    NY
  13. #13 Re: need help choosing a cam
    Apr 2012
    Dayton, OH
    If you want to be cheap you could get this then run it either in-line or stand alone, but your gonna need some extra hose probably also when you just cut your current lines and slip the hose over flare them so it doesn't slide off because otherwise it will spray trans fluid all over and probably burn the car to the ground.
    http://www.amazon.com/Hayden-Automot...rds=hayden+403
    2012 F150 STX
  14. #14 Re: need help choosing a cam
    Nov 2012
    pistolvania
    ok i am a little closer now i am stuck between xp or slx i want the powerband to be focused more on the low mid end instead of high rpms (mostly city driving) so is the slx more what im looking for
  15. #15 Re: need help choosing a cam
    Nov 2012
    pistolvania
    one more pic lol ...i am excited
  1. Need Help Choosing The Right Tires!!
    By Foxy333 in forum Tires & Wheels
    Last Post: 10-16-2013, 08:49 PM
  2. Choosing the right cam
    By Steven Monteith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2012, 11:51 PM
  3. Choosing the right (s)way
    By Axby523 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2012, 05:04 PM
  4. choosing a new deck???
    By silverbullet10 in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2011, 12:27 AM
  5. Help on choosing new amplifier
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2010, 09:39 AM
