If you want to be cheap you could get this then run it either in-line or stand alone, but your gonna need some extra hose probably also when you just cut your current lines and slip the hose over flare them so it doesn't slide off because otherwise it will spray trans fluid all over and probably burn the car to the ground.
http://www.amazon.com/Hayden-Automot...rds=hayden+403
