Temperature rising during idle Is normal, to a degree. Check and make sure full of water and no air in the system, and that the radiator cap holds pressure.
If the temp drop as soon as you start driving, it is a good indication that there is air in the system and also will need coolant, then check and find out why it is low on coolant.
