Thread: P0140 code and boost gauge acting weird
Results 1 to 14 of 14
  1. #1 P0140 code and boost gauge acting weird
    Jersey
    I got my pacesetter headers on finally!!! 12 hr job...Anyone looking to get them, be prepared to take a walk up the "trail of tears".
    Anyways I drove around, car feels way faster in the upper rpms, then i noticed my boost gauge was stuck on 20 of vacume, then the check engine light comes on shortly after and its a p0140, if im not mistaken that's a failed front 02 sensor right? does that screw up vacuum readings too? I checked all my lines and nothing is out of the ordinary, besides completely disconnecting the rear 02 for the cat but, i would think that would just give me a P0420 code, and using a 02 extension harness. Any input?
    16' wrx sti- stock
  2. #2 Re: P0140 code and boost gauge acting weird
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    P0140 code (rear O2 not enough activity) as far as the boost deal seems like it would be related to the engine codee. not sure. i know you guys are scaring me from doing these mods lol.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: P0140 code and boost gauge acting weird
    Jersey
    Quote Originally Posted by mikedinthecity View Post
    Im sorry but, I have to disagree dude. P0420 is the rear 02.
    16' wrx sti- stock
  4. #4 Re: P0140 code and boost gauge acting weird
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Yea its the rear o2 P0140, Im getting the same thing but i have a o2 sim going bad. Id get a new o2 or sim or delete it in the pcm
  5. #5 Re: P0140 code and boost gauge acting weird
    Jul 2008
    Livonia MI.
    Your boost prob sounds like too much back press, u still using a stock cat or aftermarket? It might be plugged? just a guess
  6. #6 Re: P0140 code and boost gauge acting weird
    Jersey
    I keep searching and I keep getting mixed codes. I thought P0420 code was the rear 02 (for the cat) and a P0140 code was the front 02 (on the manifold). Now im just plain confused...
    my apologies to mikedinthecity, thank you for the input.
    I have an slp catback, im also cat-less now. I could try re-connecting the rear 02 for the cat and put it in the bung and see what happens. I'm still confused as to why my boost reading was stuck on 20 vac, I would start the car, boost gauge works fine for a minute, then it's stuck on 20 vac...?
    16' wrx sti- stock
  7. #7 Re: P0140 code and boost gauge acting weird
    Jersey
    Ok I get it now...
    P0420-basically a "bad cat"
    P0140-02 sensor is not existent, or something along those lines
    I'm going to plug back in that rear 02 and see if my boost gauge readings return to normal, I'm hoping that's the problem.
    16' wrx sti- stock
  8. #8 Re: P0140 code and boost gauge acting weird
    Wausau, WI
    please read here:- P0140 Code Grand Prix - OBD-Codes.com
    and here:OBD-II Trouble Code: P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    Hope that clears things up a bit...on the first one make sure you read the last post for sure.
  9. #9 Re: P0140 code and boost gauge acting weird
    Joliet, IL
    the code is because you have no cat or no 02....the vac on your boost gauge? is it newly installed??? sounds to me like its hooked up to an evap line and not a vac line....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  10. #10 Re: P0140 code and boost gauge acting weird
    Jul 2008
    Livonia MI.
    Quote Originally Posted by BoostJunki3 View Post
    Id check to c if there is a check-valve between the intake and the gage not allowing it to release press?
  11. #11 Re: P0140 code and boost gauge acting weird
    Wausau, WI
    could you have over pressurized the line going to the gauge to peg it and cause it to be off on the reading? Not sure how you would, but I thought I should throw it out there...
  12. #12 Re: P0140 code and boost gauge acting weird
    Jersey
    update. I put back on the rear 02 and went for a drive, now i get a P1133 code.
    Boost gauge is hooked up properly, Ive been running the boost gauge since July, when i did my top-swap...
    The boost gauge reads slowly right before the ses light comes on. Then if i clear the ses light and drive the boost gauge acts normal again. Im thinking its a failed front 02 and since the pcm commands a richer air/fuel, the reading on the boost gauge gets all weird.
    16' wrx sti- stock
  13. #13 Re: P0140 code and boost gauge acting weird
    Wausau, WI
    p1133=Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
  14. #14 Re: P0140 code and boost gauge acting weird
    Wausau, WI
    DTC P1133 - 3800Pro.com Forum
    ....If you need to start troubleshooting.
  1. Grand Prix acting funny at stoplights and weird accel help
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-27-2009, 08:24 AM
  2. Fuel Gauge acting up
    By 97HoHum in forum General Tech Discussion
    Last Post: 04-30-2009, 11:16 PM
  3. please help tranny acting weird
    By ryan88z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 09:17 PM
  4. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
