Thread: seeing 7*+ of KR with conservative mods... Any suggestions??
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 seeing 7*+ of KR with conservative mods... Any suggestions??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Alright everyone, here is the mod list (1999 GTP coupe w/ 127k miles):
    PLOG
    3" Catless DP
    160 T-Stat
    K&N intake
    10.5mm plug wires
    Al104 plugs
    TB Spacer
    3.5" MPS
    Self tuned with HP Tuners
    Doing some data logging on Saturday morning, I saw up to 7.2* of KR at one point. and right around 4-5* regularly under WOT up to 98mph.... I am at a loss. AFR commanded is a steady 11.0/1 throughout the WOT pulls...
    Am I possibly seeing false KR? Should I just swap to E85 and be done with it?!?! I am getting a bit concerned at the moment. Aren't those enough breathing mods to eliminate most of that KR, especially with only a 3.5" pulley?
  2. #2 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Not knocks at all, passing on learned experience.
    The TB spacer is usually only good to leak coolant into the intake. Which can cause you issues/kr
    160 stat seems very cold for a 3.5" with a plog.
    Who's 10.5 wires do you have? ZZP had a bad run for quiet some time, if you see misfires as well and these were ZZP. It's worth trying your old wires to see if the wires failed.
    104 Plugs depending on the gap, might be too cold as well.
    You say you are comanding 11.0 afr, what is the actual afr?
  3. #3 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Thanks for the feedback. I always welcome any. I still need to log actual AFR. Don't have a wideband hooked up yet. the wires are ZZP and I just received them/installed them about 3 weeks ago...
    As far as the T-stat and plugs go, think I need to be worried about being too cold though?? That should only help with knock right? Figured I can always eliminate knock and then work my way back towards the "hotter" side of things...
  4. #4 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    May 2012
    Where winter never ends
    You need to get a wideband to log your AFR. Commanded does not always equal actual. Get a 180* T-Stat, I have read many things about the 160* T-Stat not allowing the oil to fully warm up and cause issues. 180* is good. Too cold of plugs or improperly gaped plugs can also cause misfires and then cause knock.
    2000 Regal - Winter Beater
  5. #5 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Oct 2011
    Puyallup WA
    I have 180 t stat al605 11.7 afr wb tuned headers with 3.5 pulley on genv and only would like 2 * of knock before I installed 1.9 rockers
    08 G8 GT - exhaust Tune
  6. #6 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    hmmm.. clearly I need to tweak something then. Maybe I should throw in plugs that are 1 heat range warmer? I have a 180 t-stat that I can throw in too. But why does ZZP recommend AL104s with both 3.5 and 3.4 pulleys? Not saying that their recommendations are 100% true. Just curious.
  7. #7 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Also, will be picking up a wideband very soon.
  8. #8 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    May 2012
    Running AL104s can help with knock. I stress can. It can also cause it. I am a firm believer in motors having minds of their own on what they like or dont like.
    Above all GET A WIDEBAND AND CHECK YOUR AFR. For all you know your running a 13 AFR and thats why you are knocking.
  9. #9 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    I had about 4 sets of plugs when modded. Kept trying different heat ranges and gaps until I found the best fit. There are a lot of other factors that come into play. Air density, altitude, temp, and the list keeps on going. It's not a bad idea for the cost of a copper plug to try a different range.
  10. #10 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Fair enough. Looking into a wideband ASAP. Thanks!
  11. #11 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    ZZP website for mods is outdated and mostly wrong.
    Sign up on hp tuner forums, that way people with HPT can actually see your tune and logs.
  12. #12 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Will be doing that this week
  13. #13 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Oct 2011
    Puyallup WA
    With the stock tune what it was commanding for afr was deff not what the wb was reading so before anything you need to see where you actually are at
  14. #14 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Get a wideband and make sure you are running between 10 and 12 afr at wide open. My personal favorite is 11. Then set the timing to 18* at wide open and do a few pulls. If you are still knocking its most likely real knock. Ignore bursts of knock on shifts. Let us know what happens. If you want to log wideband use the center pin on the egr connector.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  15. #15 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    18 is too high for starting, stick with stock.
    I run 13-14 because thats where is doesnt like to knock much at all.
  16. #16 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    gardner,mass
    You need to just check your plugs after going for a ride. If they are white they are burning to hot. If they are black and fouled looking they are to cold they should be a lightly grey.
    http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
    There are some pictures in there showing examples.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  17. #17 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Apr 2011
    South Dakota
    So much misinformation.... cold plugs are not going to cause kr. Too hot of plugs can, Too lean of fuel mix can, too much timing can.
    I love Decker<3
  18. #18 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Quote Originally Posted by frosty View Post
    Please do tell
    04 Comp G.
  19. #19 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Dec 2012
    troll land
    Goin off that chart my a/f ratio is dialed
    Quote Originally Posted by Ginseng View Post
  20. #20 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Apr 2011
    South Dakota
    Gotta remember that your plugs show that your cruise fueling is good. Your wide open throttle fueling will not show on the plugs
    I love Decker<3
  1. Suggestions for first mods on a N/A GP? Strict budget, and wanting to keep N/A
    By TheDarkAngel in forum General Grand Prix Discussion
    Last Post: 10-30-2013, 08:58 AM
  2. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  3. Need Suggestions on mods for 05 GP GT NON/SC
    By sLpGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2012, 09:12 PM
  4. Conservative gain estimates?
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2010, 06:59 PM
  5. Need your suggestions on mods
    By GTPMIKE in forum General Tech Discussion
    Last Post: 03-20-2010, 09:19 PM
