Thread: seeing 7*+ of KR with conservative mods... Any suggestions??
Results 21 to 40 of 55
  1. #1 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    So much misinformation.... cold plugs are not going to cause kr. Too hot of plugs can, Too lean of fuel mix can, too much timing can.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Quote Originally Posted by frosty View Post
    Please do tell
    04 Comp G.
  3. #3 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Apr 2011
    South Dakota
    Gotta remember that your plugs show that your cruise fueling is good. Your wide open throttle fueling will not show on the plugs
    I love Decker<3
  4. #4 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Bumping this back up. Had a chance to install my wideband this weekend and AFRs at WOT sit at a steady 10.9 - 11.0.. That was good to see since my commanded is 11.0. I put the 180 T-stat back in (had a 160 before). I am going to do a pull tomorrow and see if it is still knocking. I am assuming it will, just hopefully less. Any other pointers would be appreciated! Again, mod list is as follows:
    3.5 MPS
    180* T-stat
    K&N intake
    3" Catless DP
    TB Spacer
    ZZP PLOG
    10.5mm wires
    AL 104s
    Self-tuned using HP Tuners
  5. #5 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    Not trying to send you on any sort of wild goose chase; I have just been dealing with a similar situation. I explained my situation here: http://www.grandprixforums.net/threa...e-Knock-et-al)
    I ended up buy a really cheap usb inspection camera on amazon and discovered I had a chipped piston. I would go through all of the other tuning ideas first, but I ended up at my wits end with it.
    Good luck.
  6. #6 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    I actually read that write-up you posted the other week and it gave me a scare! I am actually planning on putting some 110 octane race fuel in it soon and seeing if I get any knock at all..
  7. #7 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Rest of tune-up done besides ignition?
    Engine/trans mount condition?
    Knock sensors in '97's don't normally care as much.
    Get rid of the TB spacer. It's crap. Blocks off coolant flow, causing the rear bank to run hotter.
  8. #8 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by blueguy View Post
    Oil change and plugs/wires changed out.
    All mounts are stock
    Really? I was under the impression that coolant was just for the TB to heat up during cold operation... hmm..
  9. #9 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Arizona
    Too add to this you can run the block if you grind the passage in the LIM to allow coolant to pass through.
  10. #10 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Oct 2011
    Puyallup WA
    Why don't you pull some timing see if your kr goes down?
    08 G8 GT - exhaust Tune
  11. #11 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If thats so its pointless unless you run a block heater, by the time the coolant is warm enough the crossover will make it toasty.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  12. #12 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Failed mounts can cause false readings.
    Check them.
    They need replaced, I'll bet you $20 on it.
  13. #13 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Check them.
    haha, sounds good. which ones you recommend I change? Front upper motor? any links to a good site? I am thinking about going with the ones from Intense Racing
  14. #14 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Apr 2012
    Dayton, OH
    I think he means the lowers on the trans an motor, the uppers you can flip to reduce the engine rocking back and forth or get solid ones.
    2012 F150 STX
  15. #15 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Oct 2011
    Puyallup WA
    Why I suggested to pull timing...if you pull 5 degrees of timing go wot and still have 7* of kr then it's prob mounts or something of that nature
  16. #16 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Flip the uppers 90* any direction for free.
    Then get solid rubber optioned lower mounts for the engine and transmission.
  17. #17 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Oct 2011
    Puyallup WA
    I guess if it's a chipped piston removing timing wouldn't make it stop knocking...I flipped the upper mounts when I installed my headers helped a lot
  18. #18 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by wa04compg View Post
    agreed. I can pull some timing and see if the KR doesn't change. I am planning on flipping the uppers tomorrow after work.
    Where can I find lower mounts for the engine and trans? I see the uppers for sale all over but not the lowers/trans.
  19. #19 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2012
    Minnesota
    Actually, pulling timing did get rid of KR for me; I had to pull quite a bit, but I do WOT pulls without knock during normal driving. When I took it to the track, after a couple runs and the blower was heat soaked, I ended up getting a couple degrees.
  20. #20 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Apr 2012
    Dayton, OH
    Rockauto has them along with solid mounts, I don't know where everyone else gets them tho.
    2012 F150 STX
  1. Suggestions for first mods on a N/A GP? Strict budget, and wanting to keep N/A
    By TheDarkAngel in forum General Grand Prix Discussion
    Last Post: 10-30-2013, 08:58 AM
  2. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  3. Need Suggestions on mods for 05 GP GT NON/SC
    By sLpGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2012, 09:12 PM
  4. Conservative gain estimates?
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2010, 06:59 PM
  5. Need your suggestions on mods
    By GTPMIKE in forum General Tech Discussion
    Last Post: 03-20-2010, 09:19 PM
