Thread: seeing 7*+ of KR with conservative mods... Any suggestions??
Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
  1. #41 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Edited... LOG messed up.. Back to the drawing boards
  2. #42 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    I've been running with chips for a while. I'm making an assumption, but I feel a well thought out assumption based on my knock issue from the beginning of scanning that I've been running with a chipped piston for the entire time I've owned it. 30,000+ miles.
    I'm going to put a piston in it against the advice of several on here; I plan on making sure that my clearances and torque specs are done properly.
    The car is in the garage on jack stands right now; just need to find time and motivation in my currently busy schedule.
  3. #43 seeing 7*+ of KR with conservative mods... Any suggestions??
    ^ let's us know how that works out for you
    04 Comp G.
  4. #44 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2012
    Minnesota
    Will do; you can say, "told you so," in a couple of months that way.
  5. #45 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Best of luck with the build. Would love to see some pics of what the piston chipping looks like if you get around to it.
    I have to to change out my boost bypass actuator this weekend (stock one went bad over these past two weeks). Once I get that swapped, I can try a few pulls and see what the logs tell me.
  6. #46 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    I have pics of my chipped pistons in my ride thread
  7. #47 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Arizona
    Quote Originally Posted by blueguy View Post
    Rest of tune-up done besides ignition?
    Engine/trans mount condition?
    Knock sensors in '97's don't normally care as much.
    Get rid of the TB spacer. It's crap. Blocks off coolant flow, causing the rear bank to run hotter.
    Too add to this you can run the block if you grind the passage in the LIM to allow coolant to pass through.
  8. #48 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    I may just pull the spacer off this weekend. Sounds like it really doesn't do much for me after all. Although, it is tapped for Meth, which I was considering using down the road.
    Maybe I can dremel out the portion of the spacer which prevents coolant flow???
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  9. #49 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    mind posting a link to that thread?
    2002 GTP sedan:
  10. #50 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Arizona
    Quote Originally Posted by 97AutoXVette View Post
    Look at above post #47
  11. #51 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Ahhh. You mean dremel out the spacer on the bottom to allow coolant passing. Got it. I will probably experiment this weekend on it.
    2002 GTP sedan:
  12. #52 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Arizona
    You'll ideally want to pull the LIM. Take the two bolts off the cover you'll see a little divider wall. If you dremel that wall down coolant it will easily flow to the rear head.then just use whatever method to plug the coolant holes going to the TB.
  13. #53 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
  14. #54 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Mar 2014
    Cincinnati, OH
    Removed the TB spacer this weekend completely. Just figured I wouldn't hassle with dremeling anything and ruining a good LIM, or good TB spacer.
    2002 GTP sedan:
  15. #55 Re: seeing 7*+ of KR with conservative mods... Any suggestions??
    Arizona
    It would be really hard to **** up the coolant crossover job for the LIM . once you unbolt the cover you'll clearly see what needs yo be done...not to mention the LIM that are factory desperately need to be port matched
  1. Suggestions for first mods on a N/A GP? Strict budget, and wanting to keep N/A
    By TheDarkAngel in forum General Grand Prix Discussion
    Last Post: 10-30-2013, 08:58 AM
  2. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  3. Need Suggestions on mods for 05 GP GT NON/SC
    By sLpGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2012, 09:12 PM
  4. Conservative gain estimates?
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2010, 06:59 PM
  5. Need your suggestions on mods
    By GTPMIKE in forum General Tech Discussion
    Last Post: 03-20-2010, 09:19 PM
