[QUOTE=UR LOSN;115288]the stock ignition system starts to break up at 7000..... I wouldnt trust it much past that.QUOTE]
i think 7100 is the limit on the stock ignition. not sure with what you could upgrade it with?
what psi are you going to set the oil pressure at?
have you looked into a new balancer? i believe stock is good up to 6300 after that you could be hurting the motor. zzp says going over that can cause bearing failure.
