Something in the tune is limiting the boost to only 4 lbs. What is it?
The story.
I have a 2000 GTP that went down for a build up. L26 w/ 9.6.5:1 compression, XP cam, 105's, Dbl rlr, P&P Gen V, P&P heads, P&P LIM, headers, exhaust, all the crap. you know. I previously had a DHP 1.0 PCM and thought I didnt want to try and mess with that and not have anything to fall back on so i went to my local junkyard and picked up a spare. This PCM is in my car right now. I have three different files on my comp that i switch things up with and try to figure this out. With the standard DHP 1.0 file with the proper codes removed it runs great. I see 11.3 lbs of boost and everything is good. The base file that we put in to get the car running will not get but 4 lbs of boost. I went through and looked at the 1.0 file and the base file and changed everything to look like the 1.0 file but no dice. Changed the boost ramp rate. I see 16 inches of vacuum. I know the BBV and actuator are good and in working order. no leaks, no cracks. checked a hundred times. Could the VIN number be the root of my problem. IDK. Just throwing it out there. Sorry for the novel
