Thread: Safe RPM Limits??
Results 1 to 12 of 12
  1. #1 Re: Safe RPM Limits??
    I live here. UR LOSN's Avatar
    Rockford, IL
    the stock ignition system starts to break up at 7000..... I wouldnt trust it much past that.
    If it is a built motor... what kind of bearings were you going to use?
    I would STRONGLY recommend some along the line of an "H" bearing... but if this is primarily a track car.. I would go for more of an "HX" bearing... these are made for high RPM, and offer better cooling.
    get the best money can buy. dont skimp. otherwise you will be rebuilding it often.
  2. #2 Re: Safe RPM Limits??
    TDCRacing
    Guest
    Quote Originally Posted by UR LOSN View Post
    Ok thanks for the input. I was planning on using something along those lines. I noticed on intenses website that I belive it was that hx bearings stated to only use in a track only car.Why is that?
  3. #3 Re: Safe RPM Limits??
    Donating Users chrisb's Avatar
    Bucyrus, OH
    [QUOTE=UR LOSN;115288]the stock ignition system starts to break up at 7000..... I wouldnt trust it much past that.QUOTE]
    i think 7100 is the limit on the stock ignition. not sure with what you could upgrade it with?
    what psi are you going to set the oil pressure at?
    have you looked into a new balancer? i believe stock is good up to 6300 after that you could be hurting the motor. zzp says going over that can cause bearing failure.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  1. Determining Safe Pulley Size with L67 & M90 [*]
    By gmboy in forum How To Write-Ups/Tech Tips
    Last Post: 06-18-2010, 11:56 PM
  2. Is it safe to coast in Neutral?
    By DesQ27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2008, 10:39 AM
  3. This looks like fun & safe
    Last Post: 06-29-2008, 09:13 PM
  4. what limits boost
    By deangtp in forum PCM Tuning
    Last Post: 04-08-2008, 03:53 PM
  5. Picture Limits
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 12-17-2007, 01:26 AM
