Thread: 99 dual zone HVAC problems
Results 1 to 6 of 6
  1. #1 99 dual zone HVAC problems
    s.w. virginia
    Hey all, got a 99 Gt with the dual digital(knobs with numbers on electric display) HVAc system that seems to work when it wants. I have checked for vacuum leaks under the hood but I still cant get the A/C to come on when I switch it on. Also, it has problems changing the direction of air(hot or cold) when I switch it. I will switch the direction and nothing happens, drive 10 min and it changes by itself. Any and all suggestions are welcome.
  2. #2 Re: 99 dual zone HVAC problems
    St. Louis
    Does the A/C compressor engage when you turn it on? Might just be low on freon. There is a low pressure switch that will keep it from engaging if pressure is too low in the system (a leak somewhere).
    Also, the air not changing direction from hot/cold sounds like a blend door motor. Does it change on the pass. side if you adjust the temp?
  3. #3 Re: 99 dual zone HVAC problems
    blend door actuators only control heat or cold air.
    direction of flow is the vac pump linkage broke, vac pump broke, the vac line to the vac box broke or the vac box, broke, or the climate control its self broke.
  4. #4 Re: 99 dual zone HVAC problems
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Vac pump? Since when did grand prixs come with diesels and need vac pumps?
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: 99 dual zone HVAC problems
    its more of a vacuum actuator i guess. it works off vac pressure. its in the dash and its what changes your air flow directions. ( you got 2) lots of plastic linkage that can break all on its own for no reason.
  6. #6 Re: 99 dual zone HVAC problems
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Scottydoggs is 100% correct on that. The vacuum line running off of the top of the blower to the passenger side of the engine bay next to the large relay/fuse box supplies vacuum to the motors in the dash to change direction of the air based on operator selection in the cabin.
  1. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  2. dual zone ac problem
    By 40thannPaul in forum General Tech Discussion
    Last Post: 04-02-2010, 10:43 AM
  3. Digital Dual Zone Climate Control
    By Rather B Blown in forum General Tech Discussion
    Last Post: 11-13-2009, 12:37 PM
  4. damn dual zone!!!
    By QwikGT in forum General Tech Discussion
    Last Post: 08-10-2008, 10:07 AM
  5. Dual zone climate control
    By CT Tech in forum General Tech Discussion
    Last Post: 07-10-2008, 02:05 PM
