Thread: Dual zone climate control
Results 1 to 6 of 6
  1. #1 Dual zone climate control
    SE Level Member CT Tech's Avatar
    Apr 2008
    I've got a 2000 GTP with dual zone, when you turn on the A/C, the passenger side is ice cold and the drivers side is warm, not hot like the heat is on, but nowhere near as cold as the passenger's side. Anybody had this before? Looking for a common cause and repair. I would think it's either got to be the control unit itself or a air temperature blend door sticky. Any input woulfd be a great help.
  2. #2 Re: Dual zone climate control
    SE Level Member RichCresci's Avatar
    Jul 2008
    Hey, I had the same problem, mine was the drivers blend door motor. If you stick your head unerneath the steering wheel by the pedels you can see the actuator. Theres a little metal inticator that should move when you change the the temperature, if it doesnt move its the motor. Its a $235 part unless you know someone haha(mine was $105 If you mechanically inclined you should be able to change it in about 30-45 mins, its not hard just hard to get to. Theres two screws holding it in place then a harness plugs into the top. Good Luck!
  3. #3 Re: Dual zone climate control
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ed has them for like 18-20 buxs on his website....Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    take a quarter you will see a white knob white a slot turn it one way it will get hotter other way colder. If it does not get colder one way or the other start checking your freon.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Dual zone climate control
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by CT Tech View Post
    I had the exact same thing, and could have sworn that it was a blend door issue. It turned out to be low refrigerant, and I would bet that you have the same issue. I had put the proper amount of refrigerant into the system but ended up adding almost another entire can to get all of the vents blowing <40ºF.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Dual zone climate control
    Tulsa, Ok
    Quote Originally Posted by JoshMcMadMac View Post
    If you are having to add freon there is something wrong with your ac system and you have a leak some where.
    98' GS - Sold
  6. #6 Re: Dual zone climate control
    Apr 2008
    Checked the system pressures on my guages and added half pound of freon to system. Passenger side vents at 40 degrees and driver's at 75 degrees. Pulled off actuator and worked door by hand, actuator OK and door moves freely full range. Determine foam seal on temp door deteriorated allowing hot air from heater core into driver's side vents. Proper repair would be to remove heater box, disassemble and reseal temperature door. Customer opted for cheaper fix pinch off heater hose to block flow to heater core until the end of summer.
  1. Digital CLimate control
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 10-15-2009, 08:01 AM
  2. true dual exhaust anyone?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 04:08 PM
  3. Dual Charged GTP
    By John_Shughart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2008, 12:31 PM
  4. HID Kits -- dual beam or retractable?
    By Toasty in forum General Tech Discussion
    Last Post: 01-20-2008, 02:00 PM
