Does the A/C compressor engage when you turn it on? Might just be low on freon. There is a low pressure switch that will keep it from engaging if pressure is too low in the system (a leak somewhere).
Also, the air not changing direction from hot/cold sounds like a blend door motor. Does it change on the pass. side if you adjust the temp?
