Thread: Hard to start
Results 1 to 5 of 5
  1. #1 Hard to start
    Mar 2012
    Cincinnati
    I've found a few different threads on this but none really seem to match exactly what's up with mine. So if I go out to start my car in the morning (or after it has been sitting for a long while), it takes 3-4 seconds of cranking to start it. But if I go to the gas station or something and come back out, it starts right away. Fuel pressure regulator, weak pump or what? I did have a fuel leak on a couple nylon lines to and from the tank. Those lines have been replaced. But I still periodically smell gas. Cant track down the "leak". I changed injector o-rings this past weekend. Don't see any wet spots on any fuel lines (that I can see) or on the ground. Kind of at a loss here.
    1999 Grand Prix GTP
    GXP front brakes, Comp G wheels, Dual HUD pod, Aeroforce Interceptor & boost gauge, GMPP front & rear strut brace, catless downpipe & resonator delete, homemade short ram intake w/ K&N filter
  2. #2 Re: Hard to start
    St. Louis
    At cold start, turn the key to on so the pump primes then turn it back to off, and cycle the key to on again and then see if it starts quicker.
    You shouldn't smell gas anywhere. I'd be checking the entire system over real close. Fuel can evaporate and not show a "leak" persay if the leak is small enough. Cycling the key a few times to build pressure in the system may show a leak somewhere as long as you don't start it up. Found one of my leaks that way.
    Would also help to know what year/model you are working on.
  3. #3 Re: Hard to start
    Mar 2012
    Cincinnati
    Sorry...thought you'd see it in my sig. working with a 99 GTP
    1999 Grand Prix GTP
  4. #4 Re: Hard to start
    Jan 2014
    AR
    Sounds like fairly normal loss of fuel pressure to me, I've had 2 99 GPs. I always turn the key and wait to hear the pump stop running, then crank. Usually starts quick that way but if you just roll the key all the way to crank as soon as you turn it, it will take longer to crank when cold. About 3-4 seconds, like you said. Might be a good time to eyeball the fuel filter for leaks, or replace it if its old. Like FordMan said, gas leaks don't stay wet and if you smell gas at ALL around the front of the car, triple check for wetness at the injectors and rail connections. Theres also the evap canister that could give off some smellable fumes if its in need of replacement. Thats behind the left rear splash shield.
  5. #5 Re: Hard to start
    Mar 2012
    Cincinnati
    Should have specified...my bad. Changed fuel filter with a gm filter when lines were replaced and changed injector o-rings last weekend
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. Hard to start
    By vertebrate in forum General Tech Discussion
    Last Post: 08-26-2011, 01:51 PM
  3. hard start
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 12:43 AM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
