Thread: C0161 ABS/TCS brake circuit system failure ????
Results 1 to 2 of 2
  1. #1 C0161 ABS/TCS brake circuit system failure ????
    Jan 2013
    Norcross GA
    So I just picked up a 2000 GTP 4 dr.
    Replaced rear o2, oil change, and cleaned it up
    Driving it and enjoying no SES light. I romp on it in a turn and all of a sudden the SES is back on. Pull the code and its C0161.
    "BS/TCS Brake Switch Circuit Malfunction"
    Read more at: http://www.obd-codes.com/trouble_cod...ssis-codes.php
    Copyright © OBD-Codes.com
    I cNt find anything on this, and ive searched every keyword I can think of.
    Also right side cv boot blew.
    Went to replace and after I put the new axle seal in the trans and slide the CV in it still has alot of play (side to side).. bad iinternals on trans?.
  2. #2 Re: C0161 ABS/TCS brake circuit system failure ????
    St. Louis
    Here's a thread that someone else had this issue with. May help
    http://www.grandprixforums.net/threa...ighlight=C0161
  1. Charge System Failure
    By selyse in forum General Grand Prix Discussion
    Last Post: 11-18-2013, 07:39 PM
  2. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  3. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  4. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
