Thread: mileage going down
Results 1 to 17 of 17
  1. #1 mileage going down
    Banned
    Dec 2013
    Indiana
    Other than a heavy foot, spark plugs/wires (mine are new) why would the mileage on Halfassery be dropping? Seems to be down about 2 mpg since we bought it.
  2. #2 Re: mileage going down
    Mar 2012
    NC
    Carbon buildup, different fuels, O2 sensor getting old, MAF getting dirty...lots of things.
  3. #3 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    I thought I replaced the 02 sensor! Just found the receipt. So, we'll rule that one out for now.
  4. #4 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    I was wondering about different fuels.....MAF I can check. The 02 sensor "looks" new.
  5. #5 Re: mileage going down
    Mar 2012
    NC
    Quote Originally Posted by traildog View Post
    Looks new from the outside, but on the inside is what counts. If it got carbon buildup in it, it needs to be replaced. If it hasn't been replaced in the last 75000 miles, it needs to be replaced. They get lazy.
  6. #6 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    Haven't done the Seafoam trick yet. Maybe it's time.
  7. #7 Re: mileage going down
    you could. but its best to do it before a tune up as it can foul the plugs.
  8. #8 Re: mileage going down
    oh, and dont put full trust into the dic ave mileage. its not 100%.
    the only way to really know you miles per gallon is to fill the tank, note your miles, run it down to low, then re fill the tank, now take the miles driven and gallons you just put in to figure out your mpg. simple division.
  9. #9 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    Yep, that's the way I've been checking since the DIC is showing 2mpg less. I find it to be pretty accurate.
  10. #10 Re: mileage going down
    do the math, you'll see a difference. ive done it, its not close at all. off by 3 to 4 mpg.
    cold air, warming it upin the mornings all kill the mpg on the dic. may just be normal.
  11. #11 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    I've also been wondering about the T Stat. The car runs at 180 deg. I think I read that they do better at 220?
  12. #12 Re: mileage going down
    put a 195 in there, the car may not be warming up enough and its staying in closed loop, and killing mpg.
    your engine wants to be at 210 deg's.
  13. #13 Re: mileage going down
    Banned
    Dec 2013
    Indiana
    The AeroForce always shows 180 degrees when the car is hot. I'll try a new t-stat.
    If I put a 195 in, that will make it run at 220?
  14. #14 Re: mileage going down
    Aug 2013
    McDonald PA
    Well stock stat is 195
  15. #15 mileage going down
    Aug 2013
    McDonald PA
    Just below 220 it closes at 210. It'll close the loop of the PCM isn't tuned for the 180
  16. #16 Re: mileage going down
    If you intall in a 195, you'll see temps at 195-200 almost all the time. I never see above 210 in the hot summer.
  17. #17 Re: mileage going down
    GTP Level Member
    springfield IL
    Which O2 sensor should you change upstream or downstream....or both???
  1. Mileage...
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 09:37 AM
  2. Gas mileage...
    Last Post: 04-30-2012, 07:35 PM
  3. Bad Gas Mileage
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 02:47 PM
  4. Gas Mileage
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 11-28-2009, 11:57 PM
  5. Gas Mileage
    By KSquared in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 01:12 PM
