Thread: Help replacing my Turn Signal Switch
Results 1 to 9 of 9
bps02gtp Help replacing my Turn Signal... 02-03-2014, 04:33 PM
Scottydoggs Re: Help replacing my Turn... 02-03-2014, 04:48 PM
bps02gtp Re: Help replacing my Turn... 02-03-2014, 06:00 PM
Scottydoggs Re: Help replacing my Turn... 02-03-2014, 06:10 PM
bps02gtp Re: Help replacing my Turn... 02-03-2014, 08:34 PM
Scottydoggs Re: Help replacing my Turn... 02-03-2014, 08:49 PM
goldgp Re: Help replacing my Turn... 02-03-2014, 10:43 PM
stocker Re: Help replacing my Turn... 02-04-2014, 11:24 AM
2007GPGTSC Re: Help replacing my Turn... 02-04-2014, 11:32 AM
  1. #1 Help replacing my Turn Signal Switch
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Hey guys. I tried searching for this and couldn't find much. Anyone replace one of these before? Freak accident caused me to snap mine. Got one from the junk yard and its held on by two screws to the column. One is easy to get to up top but the other on the side on the is hard. I didnt have many tools at the junk yard so I just broke part of the steering wheel so I could get the torx head on there right. My question for that screw is, do I need a swivel torx or do I have to remove the steering wheel? Thanks
  2. #2 Re: Help replacing my Turn Signal Switch
    i think you can use needle nose pliers to get that one in the front loose, then take it out by hand.
    its been a while since i changed mine, but im pretty sure i popped the wheel off too. just seemed to make life easier.
    you'll want to figure out the clips for the column plastic so you dont break yours.
  3. #3 Re: Help replacing my Turn Signal Switch
    Nov 2010
    Illinois
    The screw doesnt have a head. So i wouldnt be able to grab it with needle nose. How do I take my steering wheel off? 02 gtp in case u couldnt tell by name lol
  4. #4 Re: Help replacing my Turn Signal Switch
    on the back of the steering wheel is 4 holes, 2 on each side, stick a small screw driver it one hole, then twist, theres a spring loaded lever holding the clip, twisting the screw driver unlocks it, you feel it move. pull firm but light and hold it up, then unlock the other one on the same side, if you let it go ( aka stop pulling up, its locks again) repeat for the next side. this pops the air bag off.
    you'll want to un hook the battery, then un plug the air bag, and the wires for the steering wheel radio controls if you have them. then take the bolt off in the middle. then you need a small 2 gear puller, hook it on make the puller good and tight, then with a hammer tap the drive bolt of the puller a few times, the wheel should pop free.
  5. #5 Re: Help replacing my Turn Signal Switch
    Nov 2010
    Illinois
    Actually if I could just get the back cover of the wheel off I should be good! Thanks
  6. #6 Re: Help replacing my Turn Signal Switch
    i think the wheel needs to come off to remove the back plastic.
    you try some vice grip locking needle nose pliers? i bet that could break it free. then take it out by fingers.
  7. #7 Re: Help replacing my Turn Signal Switch
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I changed the multifunction switch out about a month ago, I did it without taking the wheel off.Altho,that would definitely make it easyer.My issue was the black male torx that hold the top plastic on.I used the lower screws that are female to fit over the male top torx,I just used needle nose visegrips on the threads.Luckily,I didn't damage them.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  8. #8 Re: Help replacing my Turn Signal Switch
    GTP Level Member
    Aug 2012
    st louis park, MN
    I did this a while ago but I remember one of the torx was a pain. If you have a swivel torx that would probably work great but I recall using a torx bit and a miniature metric wrench to turn the torx bit at that weird angle. I also had to widen the tilt lever slot in the steering column cover to get things back together. Patience was key for the torx bolts. Good luck!
  9. #9 Re: Help replacing my Turn Signal Switch
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    Quote Originally Posted by bps02gtp View Post
    I just changed mine last month I had a set of torx bits its a T-25 and this is how you get it out without removing the steering wheel :
    http://www.harborfreight.com/8-piece...ver-92630.html
    I got mine from Northern Tool but its the same concept
    Also I had more success getting the plastic shrouds back on by removing the telescoping lever
    (this was also on an 07 gp) not sure what year you have
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn signal switch... bad?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-23-2009, 08:20 PM
  3. Turn signal switch... bad?
    Last Post: 09-18-2009, 11:17 PM
  4. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
