Thread: Help replacing my Turn Signal Switch
Results 1 to 9 of 9
Threaded View
  1. #8 Re: Help replacing my Turn Signal Switch
    GTP Level Member
    Aug 2012
    st louis park, MN
    I did this a while ago but I remember one of the torx was a pain. If you have a swivel torx that would probably work great but I recall using a torx bit and a miniature metric wrench to turn the torx bit at that weird angle. I also had to widen the tilt lever slot in the steering column cover to get things back together. Patience was key for the torx bolts. Good luck!
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn signal switch... bad?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-23-2009, 08:20 PM
  3. Turn signal switch... bad?
    Last Post: 09-18-2009, 11:17 PM
  4. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
