We understand how a water pump, thermostat, and rad work in conjunction, you're misunderstanding that if you block a chunk of the rad, the temps will go up even if the thermostat is open because the rad has less surface area to disperse the coolant's heat. You need to relax, talking LIKE THIS doesn't make anyone more willing to listen to you, quite the opposite.
