It's not just a hole, there should be a hourglass shaped thing in the middle, or sometimes a small steel ball that will be in one position when the engine is not running since the water pump isn't spinning, which allows air to bleed. When the engine is started air may keep going past but once coolant hits it, the force moves it forward blocking the hole so no coolant can bypass.
