Thread: terrible gas mileage?
Results 1 to 20 of 25
  1. #1 terrible gas mileage?
    Apr 2012
    North Dakota
    i am getting probably 15 for mixed and other then a few punches a week i drive relatively preservative. what should i start to check it. it starts fine and has random misfires at idle and low acceleration up a hill.all the plugs are new(5k miles) along with new ac delco wires at the same time also cleaned all the terminals on the battery packs and put a nice amount of di-electric grease on everything.
  2. #2 Re: terrible gas mileage?
    What plugs?
    Clean air filter?
    Clean the MAF sensor.
    Any other engine codes? SES on?
    Buy a new upper o2 sensor, if original.
  3. #3 Re: terrible gas mileage?
    Topeka, KS
    What year of car?
    Tire's properly inflated?
    Random missfires could indicated a bad plug, wire, or coilpack.
  4. #4 Re: terrible gas mileage?
    Apr 2012
    North Dakota
    it is a 00 gtp i put autolite 606s and tires are set at 30 with nitrogen
    also how do you go about cleaning the maf, my k&n is clean, and no i recently checked my codes cause ses came on and only reason was my ****ty rear 02 sensor didnt go off for almost a month after the catless dp install but only code was the rear o2 sensor going off.
  5. #5 Re: terrible gas mileage?
    30 is too low IMO. I always do 34-36 psi.
    What gap did you put them at. I do .050 to .055.
  6. #6 Re: terrible gas mileage?
    Apr 2012
    North Dakota
    its .055 i do believe whatever gm recommends
  7. #7 Re: terrible gas mileage?
    remove maf and spray with maf cleaner.
  8. #8 Re: terrible gas mileage?
    Omaha, NE
    Quote Originally Posted by rynoman03 View Post
    Add ICM to this list as well as bad gaskets.
    Factory tire reccomendation is 35, I run mine a little higher.
    You clean the maf by spraying MAF cleaner on the sensor. Don't use anything but MAF cleaner.
    You said you have a catless downpipe, any other mods?
  9. #9 Re: terrible gas mileage?
    Apr 2012
    North Dakota
    just intake and 180 tstat
  10. #10 Re: terrible gas mileage?
    Dec 2011
    Philadelphia, PA
    dont feel bad blue, my gas mileage is 15.2 on my 05 n/a for watever reason lol
    AEM bruteforce intake
    Diablo 93 Octane tune
  11. #11 Re: terrible gas mileage?
    Donating User Odi's Avatar
    Chicago South Suburbs
    how much sh1t you got in your trunk?
  12. #12 Re: terrible gas mileage?
    Omaha, NE
    Its a possibility that the catless downpipe is your issue since you don't have a pcm.
    I forget the details on how that system worked before 01 though. I know 01+ Needed an O2 simulator or tune.
    sLpGPGT My 05 N/A 100% stock gets 30 MPGs, you're doing something wrong.
  13. #13 Re: terrible gas mileage?
    Dec 2011
    Philadelphia, PA
    ppl keep telling me cause its my heavy foot, but i highly doubt thats the only reason, unless i needa reset and the 15.2 read is wrong, but idk ill figure it out eventually
  14. #14 Re: terrible gas mileage?
    Omaha, NE
    I guess this hasn't been mentioned in this thread yet. Don't rely on your DIC for accuate mileage estimates.
    Do the math manually for the best results. Gallons / Miles = MPGs takes about 10 seconds to do before leaving the pump.
  15. #15 Re: terrible gas mileage?
    Dec 2011
    Philadelphia, PA
    ill do that first before i do anything, and yea it doesnt feel/look like i get 15.2 mpgs but thats what it tells me and everytime im like i doubt thats right
  16. #16 Re: terrible gas mileage?
    Apr 2009
    Fort Worth TX
    HMMM...After cross multiplying, Gallons squared = Miles squared.
    Think you better check your math. LOL
  17. #17 Re: terrible gas mileage?
    Quincy, Mass
    Do the math manually for the best results. Miles / Gallons= MPGs takes about 10 seconds to do before leaving the pump.
    Fixed
    did you replace your fuel filter? are you using 93 octane? your rear having a code up could effect your mileage, as said before, try to find someone local who knows how to tune and have them give you a custom one. that will help alot.
    No more GP 04 Impala SS Indy:
  18. #18 Re: terrible gas mileage?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    its miles divied by gallons bro but hes right the DIC is never right usually ofe by 2-3 miles per gallon
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  19. #19 Re: terrible gas mileage?
    Apr 2012
    North Dakota
    Quote Originally Posted by Swiggles View Post
    Fixed
    once i get my 3.4 i will be getting a tune also i have been told that for 00 the rear o2 sensor doesnt effect the pcms fueling only the front sensor also i have nothing in my trunk i am running 91 octane(Highest we have in nd) and i had this ****ty mpgs before the dp too and i do go by my dic but i still can only get about a week out of a tank between school and work which is MAYBE 35 miles a day if that
  20. #20 Re: terrible gas mileage?
    skip the 3.4 with only a downpipe, you'll make things worse.
  1. Terrible MPG
    By nFavor in forum 5.3L V8 (LS4)
    Last Post: 08-27-2012, 03:00 PM
  2. Terrible Gas Mileage
    By goose in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-06-2011, 07:57 AM
  3. Terrible knock..need some help!!!!!
    By FooteGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 11:57 AM
  4. Terrible Gas Mileage
    By TCO in forum General Tech Discussion
    Last Post: 12-16-2008, 01:01 AM
  5. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
