Thread: Power steering question
Results 21 to 40 of 51
  1. #1 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    Wow. I hope I don't mess up my power steering. It was leaking. If I have to replace the rack, there's a dude on here who is gonna write step by step instructions for me ;')
  2. #2 Re: Power steering question
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    What did you do pour it on the filter and install it? It should have mixed with the rest of the tranny fluid and it's not gonna be that thick. especially once it is at operating temp.....which is when you should be adding it if you want to be at the proper full level.
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: Power steering question
    Dec 2012
    troll land
    Was poured in through dipstick tube, when i sed new i didnt fresh in box i meant it had around 100 miles on it. Niether filter was dry. And fluid was def hot. Not a newb btw
  4. #4 Re: Power steering question
    Quote Originally Posted by l67ss View Post
    i still say you had an existing problem both times. your shot tranny clogged the filter.
    your flat out saying its bad or dont work, means nothing when theres 100's who used it and it works fine. it all depends on how bad your parts are when you tried the magic fix fluid. its not always a win.
  5. #5 Re: Power steering question
    Dec 2012
    troll land
    You can believe what ya want, hell i used to believe in santa clause.
    I did not say it wouldnt work, i said in TWO SEPARATE occasion of using TWO DIFFERENT PRODUCTS i had bad results. I was saying buyer beware.
    The carb was in good working order with a CLEAR fuel filter and a relirively new jcwhitney tank . If it was crap frim the tank it would have shown up in the filter.
    On the trans it had 60k on the rebuild, fr, had just been serviced, the crap that came outta the filter looked and felt just luke red tinted lucas. If it was from being a "shot" tranny, there would have been chunks and burnt fluid, neither was present.
  6. #6 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    No fluid under the car this morning. :-)
  7. #7 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    2 drops of ps fluid under the car this morning. So, it hasn't quite stopped, but, it's significantly better.
    I was told it might take a while, so, I'll let you all know later.
  8. #8 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    Dry as a bone under the car this morning....I think it's working. How long? Who knows........
  9. #9 Re: Power steering question
    Denver
    Replacing the PS rack is not all that bad (should it give out). Drop the back of the subframe - it should take 1/2 a day to replace. Reman units with lifetime warranty are something like $200.
  10. #10 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    Quote Originally Posted by SJAndrew View Post
    When it goes completely, the car will still be steerable, just really hard, right?
  11. #11 Re: Power steering question
    when it goes bad it will start out as stiffer to the left, easier to the right, then later it will be like turning a 300 lb wheel.
  12. #12 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    I guess I better tell my son to start pumping iron.......
  13. #13 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    Oh yea, if it makes any difference, I'll be doing the work on my back with the car on jack stands.........
  14. #14 Re: Power steering question
    Quote Originally Posted by traildog View Post
    i dont know any other way but on my back lol
    what i did was to back the car up on ramps, then jacked it up via the middle of the front sub frame as high up as i could. then put the jack stands under the front rockers. ( mine are solid, no rust) make sure yours are solid before you put a jack stand there.
    this gets the whole car off the ground. for a big person like myself i liked the extra room under there.
  15. #15 Re: Power steering question
    i drove for a month on a dead rack, its not fun, and really not safe, the wheel is very hard to turn even at speed. it wont move at all if stopped.
  16. #16 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    It seems to be steering fine right now. Although it's a bit "bumpy" if you know what I mean.
  17. #17 Re: Power steering question
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    I either have a bad rack or pump. And trust me. ****ing sucks driving right now
    2001 sliver gtp her name is Reagan
  18. #18 Re: Power steering question
    Banned
    Dec 2013
    Indiana
    I guess I'm going to start looking at replacing it. How can I tell if it's the pump or the rack?
  19. #19 Re: Power steering question
    Oct 2012
    Fort Wayne, Indiana
    Haha don't ask me. I don't even know which one mine is
  20. #20 Re: Power steering question
    thats the trick. if the rack is leaking, change em both. the pump is cheap.
    my car the pump started to whine, and the the steering got hard unless i gave it gas. i changed the pumps, cause will what else would ya do lol and then the rack was dead, it got no power at all.
    changed the rack and its back to butter.
  1. '98 GTP power steering pump question
    By DrKavorkien in forum Introductions/Noob Questions
    Last Post: 08-31-2012, 10:50 PM
  2. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  3. Power steering question
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2011, 03:00 PM
  4. power steering question please help
    By mcsddd in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
  5. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
