Thread: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
Results 1 to 11 of 11
  1. #1 Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    Jul 2010
    Warrington, PA
    Hi - Just wondering how hard this is for DIY.
    I have a 2000 GTP and I ran over something and caused a leak - looks like there is a small flex line where the Y pipe connects to the rear exhaust between the engine and firewall.
    It seems hard to get to but I was wondering if there's some tricks to getting in there. Is there a flex line that's held in with clamps that I can replace without welding?
    thanks in advance! My GTP has 182k miles and runs great with no major repairs.
    -Dan
  2. #2 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    some pics would help. but im pretty sure the manifolds are cast and you cant weld cast well. it never lasts.
    not sure whats broken, but you may need a new Down pipe or the whole rear manifold. hard to say with out seeing it.
  3. #3 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    Jul 2010
    Warrington, PA
    Here's a pic - I can reach down between the engine and firewall with the engine running and feel the leak in the ribbed portion of the pipe. I am thinking that the manifold is OK and maybe that ribbed portion is part of the downpipe?
    Y pipe to rear exhaust leak between engine and firewall on 2000 GTP Attached Images
  4. #4 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    thats part of the down pipe. it unbolts at the flange in the pic. and 2 more bolts at the cat to res flange.
    time to get a new one as i dont think its fixable. unless the gasket blew out. it looks like someone has been in there before maybe.
    if you seafoam the car you'll see exactly where its leaking from, or when its cold out on a cold start may show it as well.
  5. #5 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    Jul 2010
    Warrington, PA
    Ah so this is the pipe with the infamous u-bend? as in: http://shop.zzperformance.com/store/...Downpipes.aspx
    And I guess the pipe has a cat so if shopping on rockauto it's in the cat section.
    It looks like the zzp upgraded is on-par or cheaper price wise. I guess it's never too late for a smaller pulley :-)
    thanks for the info!
  6. #6 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    id get the 3 inch DP. 3 inch catted is 220.
    but a walker is 250 ish. direct stock replacement.
    or find a used one, they pop up on CL and here as well sometimes.
  7. #7 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    Jul 2010
    Warrington, PA
    btw took about an hour to remove it with the car on jack stands so it wasn't a big deal. I ordered the 3" catted unit from zzp for about 250 shipped - what a great deal. We'll see if it makes a noticable improvement.
  8. #8 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I dont think you'll notice much of an improvement. I wouldn't go with a smaller pulley as you mentioned earlier without headers or at least a PLOG. But you may as well go with headers as they are only a tiny bit more than a Plog manifold
    I went NA when a whore left -$300 in my bank account.
  9. #9 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    he would ok ish if he added a plog. id leave the pulley alone till something that or headers are added.
  10. #10 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    GT Level Member Exile's Avatar
    Chicago
    Quote Originally Posted by torqueaddict View Post
    Torqueaddict, did you buy the bolts for the new DP install yet? Just wondering what bolt size you got for the DP-manifold link? I have a DP that needs to be installed as well.
  11. #11 Re: Y pipe to rear exhaust leak between engine and firewall on 2000 GTP
    Jul 2010
    Warrington, PA
    Quote Originally Posted by Exile View Post
    Will get back to you on the bolts - thanks for the advice on the pulley. Too many projects now - still finishing a 350 to 455 swap in my 72 Skylark, and I'm driving my 89 GTA in place of my daily driver (the GTP) which isn't so great for winter :-)
  1. 2000 GP GT Engine Fire - Oil Leak Suspected L36
    By stevecihak in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 04:18 PM
  2. Intermediate exhaust pipe
    By reem98 in forum General Tech Discussion
    Last Post: 03-06-2013, 10:29 PM
  3. Exhaust Down Pipe
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 03:10 AM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
